MS460 PTO Crank Seal Problems
jacktheripper
Papa Squat
11:31 AM
Wyoming
I recently got my project ms460 together. Started and ran good, but then started acting like it had an air leak after a little bit. I pressure tested it, and found the PTO side seal wasn't sealing right - the outer lip was slightly over the groove where the oiler snap ring rides, and was leaking. I tapped it in some more to get the lip to seal. It pressure tested fine.
Ran it again, and after a little while, started acting funny again. Pressure tested again, and the seal wasn't sealing. Popped the seal out, and found that the inside lip had been rubbing against the inner bearing race from being tapped in too much, and had started to fall apart. Good thing I caught it before the spring had time to come apart in the crankcase.
Tapped in a new seal, and I went too far in again. I could see the rubber bulging out because it had again bottomed out on the PTO bearing inner race.
I'm beginning to think that I messed up on this one. I used the Wolf Creek Saw Shop kit with SKF/New West bearings. I'm wondering if the PTO bearing dimensions are different, causing there to be not enough room for the seal to seat perfectly between the oiler snap ring channel and the inner bearing race.
Does anyone else have this experience? Can anyone share pictures up close of their PTO side seal riding on the crankshaft? I'm curious about how close the factory outer seal lip is to the snap ring groove.
I have a feeling that I'm going to have to split cases again...
FederalQ
12:31 PM
NE Wisconsin
Isn’t there a tool of some sort to put over the crankshaft to slide the seal over to prevent rolling the inner diameter edge over? I thought I saw something in the pdf service manual from this site.
jacob j.
Only the weird
10:31 AM
Coastal Oregon
Does the kit include an OEM PTO side bearing or Chinese? I've never had a problem with the OEM bearing and seal on the PTO side of any 046/460. I've heard from several guys who've had trouble with the Chinese seals and bearings though.
jacktheripper
Papa Squat
11:31 AM
Wyoming
That is not my issue. Seal lip is on the crank surface evenly.
jacktheripper
Papa Squat
11:31 AM
Wyoming
It was a New West Products bearing. Not sure country of origin, but have heard good things about that company.
jacob j.
Only the weird
10:31 AM
Coastal Oregon
Typically how I set the seal on those is with the metal side of the seal just flush with the outer edge of the bearing. A lot of guys set the bearing depth using the oil pump - I set mine where the lower outer step of the bearing is even with the edge of the bearing pocket in the case. I don't like to use the oil pump body because I've seen variations in the how closely or not the oil pump body sits to the top of the bearing pocket.
jacktheripper
Papa Squat
11:31 AM
Wyoming
Typically how I set the seal on those is with the metal side of the seal just flush with the edge of the bearing. A lot of guys set the bearing depth using the oil pump - I set mine where the lower outer step of the bearing is even with the edge of the bearing pocket in the case. I don't like to use the oil pump body because I've seen variations in the how closely or not the oil pump body sits to the top of the bearing pocket.
Yep, that's how I did it. It might just be that I've got to get the seal just right there... Do you or anyone else have a picture of a 046/460 with the seal installed, oil pump removed? How close is the outer lip to the snap ring groove?
Woodwackr
11:31 AM
ID
is the seal too tall? OE or aftermarket of some sort?
redline4
I'm huge in Japan
12:31 PM
Rosholt Wisconsin
You can scroll through my build thread. I took pics of pretty much every step.
jacktheripper
Papa Squat
11:31 AM
Wyoming
This is the thread that I've been looking for. I read it a while back. I feel a little less crazy too, because your PTO side looks just like mine does. I just think I'm messing up the install on my end. I ordered some new crank seals and I'll give it a shot after Thanksgiving
1:31 PM
I cheat and use the factory installation tools. There is generally a piece with the tool sets that sits over the crank threads and will cover ant lip/step on the crank. When I’ve taken a short cut and haven’t used them, I’ve had a few issues where the inner lip got caught in a groove, or the step in the crank caused the inner lip to prolapse out, causing the seal to fail. When you don’t have that part available, it helps to oil the seal very well and rotate it over any lip or ridge slightly cocked, making sure you don’t flip the lip. AM seals are particularly more prone to this than OEM seals.
redline4
I'm huge in Japan
12:31 PM
Rosholt Wisconsin
You can use this plastic from some type of packaging rolled into a cone so that it fits around the crank shoulder to use as a guide for the seal over that lip as a home made tool. I've done that. I also slobbed some mix oil on it to help the seal go on.
Squareground3691
1:31 PM
New England
Standard procedure for me , or get the OEM sleeve ,
jacktheripper
Papa Squat
11:31 AM
Wyoming
I definitely understand the concern with getting the seal seated. I feel confident that the seal was not prolapsed from not being able to slip over ridges/shoulders on the crank. The main concern is depth. If the seal is pushed in too deep, the inside rubber ring (that the inner spring fits around) will contact the inner PTO bearing race. If the seal is not deeply tapped in enough, the outer seal lip will ride inside the snap ring groove and not seal. It just seems there isn't much room for error with seal depth on this saw.
Brad Button
10:31 AM
Angels Camp,Ca.
I usually use a socket the right size to install the seals, but on some, the press sleeve works better to get the seal to the right depth along with a light coating of Dirko.
1:31 PM
The only other thing that comes to mind is the position of the crank inside the case being too far to the left
jacktheripper
Papa Squat
11:31 AM
Wyoming
Ok, so here's an update on the situation:
After replacing the seal perfectly a couple of times in a row, and subsequently burning them up again, I pulled the second burnt up seal back out and found that my plastic bearing cage was gone. Totally disintegrated. What the heck.
So I ordered OEM bearings and split the case. No apparent damage to the rest of the saw from the burnt up bearing cage. Only issue was the spark screens were plugged up with melted plastic. Everything was reassembled, and vacuum and pressure tested fine. I started it up and it very quickly started acting like it had an air leak. So I tore covers off, removed clutch and oil pump, and pressure/vacuum tested. This time, there was a slow leak apparent. I used soapy water to pinpoint it to one of the oil pump mounting screw holes. So I went searching on the web.
I found this thread: https://www.arboristsite.com/threads/ms460-air-leak.295785/
The poster had found a similar air leak through the screw hole. They tore the saw apart and found a strange crack where the bearing seat insert meets the casting on the PTO side case half. According to a poster, they had a similar issue and fixed it with green loc-tite.
It got me thinking - I remember inspecting the PTO side case half when the saw was apart, and I saw a similar strange bevel/crack very much like the one in the post above. So I think that I have actually been frying my seals and bearings due to a heavy air leak that may only be showing up when the saw is running and the crack begins to leak, torching the surrounding area.
Has anyone else had this experience?
Woodwackr
11:31 AM
ID
I have a 064 case that had that issue. Turned out that a previous owner had used too long a screw...not what came out originally. It popped the mag there just enough to leak. A little JB and the correct screw seemed to fix it.
