tree monkey
- 10:31 AM
- Dec 14, 2015
- wi
the thing is your both right and your both wrong, it really depends on what you want it to do, work or race
I do simple carb mods that don't require a flow chart or a Phd. I try to bring in more air and more fuel at the H jet. That's why this thread really got my attention
I like a strong work saw....... That had better well be able to win a few races!the thing is your both right and your both wrong, it really depends on what you want it to do, work or race
If you go back and read the '7900 carb upgrade' thread on AS - http://www.arboristsite.com/community/threads/dolmar-7900-carb-upgrade.229528/
You'll see where Rich (Poleman) and I ran into the problem of too much fuel in the idle circuit (because we drilled the idle jet) and the idle became hard to adjust. We fixed that problem by drilling one of the .5mm air bleed/transition holes out to .55mm. That's all it took and the idle became adjustable.
You will also read in that thread where Rich tried the modded carb for the first time and commented on the increased torque. It made the saw a much more capable work saw.
As far as atomisation of fuel, this is a two-stroke, it has a huge egg beater in the crankcase called a crankshaft that is thrashing things around quite well. However, it is 'vaporisation' that really counts, and that is done mostly in the hot cylinder when the fuel mixture is fed into it via the transfer ports.
Wonder what the bore size is compared to a WJ 48?
Undercarbed and under powered! Lol.well the 39 is 18.26mm venturi IIRC. the throttle bore is perfect for the 390 intake boot. after running the 39 on a stock 390 i am convinced that the they are undercarbed.
Nice AV I hear though
You just haven't ran a good ported 066 then, I have one and I know a few others that will smoke a 390 any day of the weekthey rag doll a 660 when both ported. i ran a 660 on the right of way a few weeks ago. i don't mind it but i always miss the full wrap on the husky. the 3/4 wraps suck!
92 cc I believe. But anyway.......... Carbs, we're supposed to talkin about carbsvery well could be, isn't the 660 a 94cc saw to though? it's more comparable with a 395 IIRC it's not even really about the power for me. i really like the way a 390 handles in all aspects of my job. anyways, maybe we should not derail this thread til the end lol
I run the Smittybilt 660s at the NY GTGs, and they are very stout! One of the two has an 054 top end, but they are both beasts!
