Ms362 exhaust leak.
SawAddictedFarmer
9:02 PM
I pulled the jug on my 362 to check some stuff and after putting it back together it was leaking around the muffler where it bolts to the cylinder. I tried cleaning the muffler, gasket, and cylinder and putting it back together but it still leaks.
This is what's on there.
Anybody have a fix for this? Do I just need a new gasket?
Would this fit?
Thanks!
SawAddictedFarmer
9:02 PM
After a good run, retighten the two bolts on either side of the port holding the can on.
No, that gasket will not fit, I recommend the OEM gasket.
Thanks! I should be able to give it a try this afternoon.
The fact that it's oily from exhaust leaking out isn't going to matter?
hacskaroly
2100 Fanclub Member
7:02 PM
Northern Idaho, Ehh
Well messing with a hot muffler could be fun but I guess I can give it a go.
Use the hot mats out of the kitchen to handle the muffler and you should be good to go!! :D
Edit: Yeah, I didn't think that through, no you don't want to take it apart after running, just tighten down. Later if you can get a screwdriver with a paper towel or something to work in and wipe up the extra oil you should be good to go.
SawAddictedFarmer
9:02 PM
Standard carb. I had it tuned right before pulling the jug and a timing advance. I got it close but safely rich yesterday since I only needed it to cut my other saw out.
Duane(Pa)
It's the chain...
10:02 PM
Centre County
Speaking of… what is the best plan for a stripped muffler bolt hole? Half the threads came out with the blessed lok tite (different application)
