MS261CM M-Tronic Issues and Many GFY’s
10:36 AM
Do coils actually “advance” timing, or do they just retard it for low rpm and then go back to wherever they are set statically?
Guess it’s the same difference in some ways?
Do MT coils store the energy of both magnet packs, fire twice, or does the magnet pack that passes at BDC just a sensor for the MT fuel system?
DND 9000
4:36 PM
Germany
Ignition coils and of course the m-tronic control units too advance the ignition timing since many years forward and backwards, depending on the current running conditions.
The 2nd pair of poles on a m-tronic flywheel is for powering the m-tronic system. Control units don`t store energy if the machine is turned off, but during starting they wake up within a few milliseconds.
Example: On the TS 500i control unit, the wakeup and synconizing process during starting is done in 150ms.
CR888
2:36 AM
I’m not Running anything @ 50:1.
Neither am I but I recommended changing oil ratio as 800 motul at 32:1 is a lot of oil. Other oils may be fine @32:1 but 800 motul viscosity is thick. So to rule it out I suggested changing oils or at least going back to 50:1. Motul may well be more oil @60:1 than other oils @50:1 :idea:. Viscosity index of oil can be important.
hseII
Heef
10:36 AM
West Georgia
That Makes sense.
I wonder if Julian has composed a chart?
@Redbull661
CR888
2:36 AM
This guy has some good thoughts on common 2T oils found in the states. He made a ratio calculator to work out what ratio oils should be mixed at based on max rpm, displacement, load, viscosity, & what group base stock the oils are made of (1-5). Might be an interesting read for some, I don't agree with everything he writes but he has got a lot of good info learnt through building push bikes with air cooled 2T's.
http://www.dragonfly75.com/motorbike/oil.html
Cobby08
I’m a face down ass up guy
10:36 AM
Central New Yawk...
The northerners got weird gas. Winter blend, summer blend, *f-wordeduperthanasoupsandwich blend.
I'm with Redbull.....
It's fuel, or oil related.
Suck my trumpet, cow boy...
Haaaatttttterz
Redfin
Meh...
10:36 AM
Central Pa
The 180* set of magnets is reverse polarity from the primary set.
