- 5:11 PM
- Dec 30, 2015
- Centre County
Seems a little high; is it made in the USA?20 dollars is 20 dollars.
Eye run a lot of “advance”. Is that going to be ok with you?Well duh.
Sooooo...this all means I should buy one with the holes in the side to stick my orange screw stick thingy in to make adjustments on my own?![]()
No.
Motul is some thick stuff, & with Extra the heat & added timing, it doesn’t do well @ 32:1.
Trying to talk myself into mtronic...but "simple" part of me says stick with carb...
What kind of oilI think if I remember correctly my MOFO 261cm V1 was a .22 squish. I have been running an oil cocktail of 32:1 since I got it from Al. I have not experienced any of these running issues at all.
My plug looked brand new, lightly golden brown.
Maybe I should consider myself lucky???
I run 16" 3/8 full chisel or 18" 325 full chisel with this 261.
i told him the same thing but he’s like his brother and don’t listenThe ole sniff test...You might be over thinking the mix oil conundrum Jiff
That's enough from the peanut gallery.i told him the same thing but he’s like his brother and don’t listen
501 pretty soon. GfyThat's enough from the peanut gallery.
You gonna cut any wood at all with any of your 500 saws? Or just look at them on the shelf. SLACKER.
