- 1:50 PM
- Oct 18, 2016
- GFY
Dang makes me want to check out mine now lol.Taking this thing apart now that I have a wiring harness in hand...found this.![]()
So no plastic or metal ring that sets into the edge of the intake just before the carb. First I've seen that but I wondered as the manifold does have the raised bead around the perimeter like a formed in O-ring to seal. I will keep pushing on.looks ok to me...#32 is in place in the "manifold" ...its a bear to get back in place to stay on while "reversing" the tear down process....its a weird way that they "clamp" off the manifold to the "case" with just that "plastic sleeve" too. first time I saw that I was like...wah da fug.... wheres the clamp ?
OK. #32 is not the intake divider..You are missing a piece there Jimmy.....
just dug through my pile of 201 carcass...not there either.Sucks working after someone that thinks “I don’t know why they put all this crap on at the factory. You don’t need it”
MIA. No surprise either looking at other work done on this saw.I'm wrong...that "Bridge" is part of the manifold. The little divider is not on carb or manifold?View attachment 207088
PM inbound!Yours if you want them. Just PM me an address.
Makes sense!They run like crap without that carb ring. Even if you gut the intake, you want #32. The jets don’t work properly without it.
That is exactly what this saw is... lots of idiots who don't care.Sucks working after someone that thinks “I don’t know why they put all this crap on at the factory. You don’t need it”
