ms 462
K Mueller
2:14 AM
Alaska, USA
Anyone have a part number for large dual spikes
Tried putting this style on my 462 and the chain roller catcher wouldn’t line up.
K Mueller
2:14 AM
Alaska, USA
I heard others using the old p/n with a bit of grinding to fit.
I did take a dremel and ground the inside of the spike so it would bolt to the clutch cover. I had the roller catcher mounted to the outside spike and it was a half inch from lining up with the inside spike. I’ll mess around with it some more I guess. It was a brand new setup so I know the roller catcher isn’t bent.
ferris
12:14 PM
Germany
Thanks.
Different part number than the ones I have But it’s the same spike... they fit the 1122 series and 461 etc.
There is the problem, they spikes on the 461 460... are different on the clutch cover. They won’t fit on the 462.
You need the ones from the 440 660 661
~WBF
Thecallofthewildanswered1989-2017[PAID IN FULL!]
11:14 AM
Uk
Sounds like you need a longer roller catcher then.
The dogs are mounted where they are supposed to mount are they not?How would a different set of dogs be different with that catcher?
Lightning Performance
6:14 AM
East of Philly
Thanks.
These things get tricky with spikes. My 361 wears the same as the 362. OEM 029-390 inner AM outer. Small clutch cover. Standard catcher. Works good.
00wyk
11:14 AM
Ireland
View attachment 172152 My 462R turned up today stuck a bar and chain on it and fired it up very impressive throttle response
19dce26d-7e18-4b3a-8ebe-dc091ac6c4d3-jpeg.172152
Did you use that saw to spackle that wall? ;)
AlexSwan
8:14 PM
Kyogle, Australia
AlexSwan
8:14 PM
Kyogle, Australia
Hey everyone, it's been a year since the last video and honestly this is the first tree I've cut since. A tricky one too, backed onto a fence 2 metres away from the road, only one way for it to go.
Firewood season is here so hopefully the 462 will see some more action...
Cheers
