ms 461 woods port race thing
2:25 AM
But in the same combustion chamber? Perhaps? I think we need Julian here!!!
No, but the theory still stands. The cool air comes from the recoil fan. The air is definitely warmer by the time it gets to the other side
Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:25 AM
Provencal, Louisiana
I agree with Keith, the heat dissipation from one side of the cylinder to the other will not be immediate.
However, the differences will likely remain small.
It takes heat to have combustion and make carbon. If these wash patterns are apparent its not as hot in thoso spots. Lean the saw out and u will see the wash disappear and thoso areas have heated up. JMO
tree monkey
1:25 AM
wi
the leaner I can run it the better, or more true the pattern will be
paragonbuilder
2:25 AM
Norwich, CT
I was thinking it sucked air across the fins as opposed to blowing, but now that you say that, I see.
Still find I hard to believe the piston itself has a temperature spread across its crown.
But I’m still learning
Keith Gandy
1:25 AM
That statement should clue alota folks in on oil used and whether it combust well, how well the saws tuned by wash patterns or not, and making power or not? Oh hell, I said OIL!!! :couch:
Keith Gandy
1:25 AM
I see alot of temp. Differences internally happening instantly that wont be reflected externally with a temp. Gun
