ms 461 woods port race thing
paragonbuilder
10:13 AM
Norwich, CT
if I get a gain I can grind it in, but witch way?
Just a thought. You have your exhaust where you want now, and it’s a loss to go more. So that piston is done. What if you grind the angles one way on it. If you maintain or gain it’s a win. Cuz it’s already slower the way it is.
I’m thinking I’d try upwards towards the center.
XP_Slinger
They’re Just Saws
10:13 AM
Central NY
Primary downward for lift, secondary flat to continue the “bottom up” fill and push exhaust out.
Disclaimer: theory only, don’t let the smell of my brain farts distract from actual experience.
paragonbuilder
10:13 AM
Norwich, CT
Also you could start with just the primaries, then angle the secondaries after you maximize gains with that if there are any and see if there are any more?
paragonbuilder
10:13 AM
Norwich, CT
Downward towards exhaust?
angelo c
Coal Member
10:13 AM
You mean like 026 dome?
that's where I was...you passed me doing 90mph with the slanted then Scott blew by us both with the staggered slant...
im limited by what my mind will allow in by what my tooling will do. I had no way of mentally building slants.
and only a crude understanding of doming one.
but am sure as chit finding this discussion better then learning about Chithole locations on TV
paragonbuilder
10:13 AM
Norwich, CT
It’s the best thread on here in a long time! That’s for sure!
Keith Gandy
Maxima K2 40:1 87 Pump Gas
9:13 AM
Provencal, Louisiana
Scott that looks better, but times were worse? Why do you think it’s washing better on the flywheel side?
Flywheel fan is keepin that side of the cylinder cooler and not combusting as much as the otherside
XP_Slinger
They’re Just Saws
10:13 AM
Central NY
Yes sir
Never thought of that. I thought it was a very slight difference in entry pressure caused by the clutch side ports being a hair lower than the flywheel side
