CR888
- 11:39 AM
- Jan 9, 2016
- Australia
Also keep things in perspective, guys on forums see a few fines get past their filter & think the issue is far more of a problem than it is. Sure piston wear and contamination can occur from poor filtration but with a few tiny wood fine here and there a good pro saw can run a very long service life with no major issues from it. You may well be better off saving the money you can spend on a high end AM filter and putting it towards your next saw. In some cases action must be taken but not always, a little grease often does the trick. Many PSP's running expensive AM filters are not doing it cause their last pro saw ended its life due to poor filtration. Just my opinion.
