Most common air leak areas on a 372?
3:59 PM
Funny man cause this saw has very little time from new.... fricken sweden qaulity control really does stink sometimes. 2017 was a bad year for saws!!!
im glad you have confirmed it. I am thinking of checking the surfaces for flatness but i dont have oem gaskets.. i do have aftermarket but why wouldnt a hit of motoseal on both surfaces do the trick for aftermarket gaskets?
Worked for me many times.
brad ruch
3:59 PM
michigan
I'm sure there flat.i would motoseal it with the gasket.and let it set overnight before adding bar oil.make sure the cars are clean and free of oil and dirt also before the sealant.
Sent from my Pixel 2 XL using Tapatalk
kneedeepinsaws
1:59 PM
Oil Country
They will be fully clean and scrubbed before any work is done. Not going this far to have a piece of sawdust get pinched in between the cases and im right back to square one
3:59 PM
So far thats my plan.
cant get the tank vent out, i can see the puck but the sleeve is inside after the green 90 barbed fitting came out.
The only gasket that failed me was black and brittle i haven't seen those for sale for many years
The green or grey have been fine.
brad ruch
3:59 PM
michigan
Thats funny the one I did last year with three bond was a dam black gasket.[emoji23][emoji23] and it failed
kneedeepinsaws
1:59 PM
Oil Country
I use 1184 on the surfaces. :)
Product of Merica not kanata
we got motoseal up here itll have to do, im tired of ordering stuff right now ;)
how does a bar oil leak cause the engine to overheat?
I did notice that the saw would get real hot on the top cover, too hot touch from start to just idling after a few minutes.
3:59 PM
I haven't seen them in 3 or more year's
Semi soft at first
They hardened and chipped out in the oil tank area
I had one and a friend had one do the same on 372s
Mattyo
Youtube speciawist
3:59 PM
Farmington, CT
fyi I put seals and o ring in your package lol :)
kneedeepinsaws
1:59 PM
Oil Country
BA7FD820-B1F2-46C1-8E0E-20A75FD0A5E6.jpeg E3C3064C-BC49-4CDA-B9BC-FA411AB6C145.jpeg Split the cases. Has a black gasket, looks like possible leaking from oil reservoir bottom right to crankcase, also oil penetrating in other spots as well...
got some of the FSM pages printed out so i do this right. Mattyos tool arrived as well so putting this back together should be good. gonna give these a bath, but first gasket removal and remover then strip it fully and have it squeeky clean.
bearings appear fine. Regardless they are getting replaced with nachis courtesy of mattyo!!
kneedeepinsaws
1:59 PM
Oil Country
Would you recommend the husky ones i have or the ones you sent?
I watched your video on putting on the one side with the coke can ill watch it again as a refresher.
kneedeepinsaws
1:59 PM
Oil Country
Don't need a coke can.use the husky ones.
I dont have the tool for seal install, is there a good way to gauge the depth of the seal on the flywheel side without the tool?
BuckthornBonnie
3:59 PM
Penn Yan, NY
On 372s there is usually an area that’s visible after you pull the old seal. Take pics and try to measure that depth. If I recall correctly, it’s deep enough to be on the edge of the paint area. I usually don’t trust paint as an indicator, though.
kneedeepinsaws
1:59 PM
Oil Country
Thank you, ill take a look.
gonna turn off the over lol, looks like i am at a hurdle here.
i have two bearings, one is sealed and one is not, what goes on what side?
