- 12:15 PM
- Jan 8, 2016
- Farmington, CT
The clutch holds the bushing in and aids the seal. So no this is not a problem.
That i do not know... i will check that as well when i am home.It has new carb...OK. good.
Did it hold pressure on rotation of the crank during the pressure test?
How about vac?
I am using a hutzl farmertech aluminum one. Ot does look tho like there should be another gasket of rubber or cork between the two tho... bottoms out way to easyIt is very common/easy to over tighten the carburetor mounting screws on a 372, causing the plastic mount to pucker and warp causing an air leak at the end of the manifold boot.
Good info, thank you, there is a large part the ignition plays in tuning it would seemI've had coil problems cause similar trouble recently. My MMWS 346 would not idle at all after it warmed up. I swapped carbs, pressure tested, fuel line tested, etc. Finally I swapped coils from my 353 and it's all good.
I burned the top end on my brother's 61, did a top end swap to a 272 and only after a lot of messing around did I realize the whole trouble was caused by a bad ignition. The saw would act really rich and "4 stroke" at 7-10k rpm, then if I'd lean it out it would sound like it was 4 stroking at about 13k. Sounds good, eh? No, it was super lean, but the ignition was just strong enough to light it up to 13k and then it would 4 stroke because the ignition couldn't light a full proper mixture. If fattened it up at all it would fall on its face. With only a coil swap it came back to normal tuning. The H needle was able to fatten up over 1/2 turn to properly tune.
My BIL has a 395 that would hunt like crazy at idle and tuning would cause high and low speed, stalling, etc. We found a thin spot on the high voltage lead that was grounding against the cylinder fin. At full throttle it vibrated at a frequency that it 'usually' didn't cause trouble.
We taped it up and moved it away from he cylinder and all came back to normal.
Good luck.
