tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #1 I like to get everything I can out of my way stock port numbers
mdavlee Hillbilly grinder Local time 7:24 AM User ID 279 Joined Dec 28, 2015 Messages 14,194 Reaction score 64,634 Location TN Jan 19, 2016 #2 You done yet?
Warped5 Pinnacle OPE Member Local time 6:24 AM User ID 432 Joined Jan 7, 2016 Messages 984 Reaction score 2,761 Location Northwest IN Jan 19, 2016 #3 I want to see where he cuts a gasket from a beer can.
Gunn Yay sawz Local time 6:24 AM User ID 529 Joined Jan 13, 2016 Messages 503 Reaction score 939 Location Plover wi Jan 19, 2016 #4 heh, you must like Mt Dew
Elim S=D/T Local time 7:24 AM User ID 398 Joined Jan 3, 2016 Messages 101 Reaction score 289 Location West Virginia Jan 19, 2016 #5 Looks like the good numbers are under the cover up sheet of paper.
jmssaws Banneded Local time 6:24 AM User ID 291 Joined Dec 28, 2015 Messages 10,024 Reaction score 37,296 Location Missouri Jan 19, 2016 #6 Is a 2188 a 390xp with strange coverings?
Milkman31 Pinnacle OPE Member Local time 6:24 AM User ID 16 Joined Dec 4, 2015 Messages 589 Reaction score 1,695 Location Tn Jan 19, 2016 #7 Warped5 said: I want to see where he cuts a gasket from a beer can. Click to expand... I see lots of gaskets!!! Lol
Miller Mod Saws Chainsaw Masseuse Local time 6:24 AM User ID 317 Joined Dec 29, 2015 Messages 2,070 Reaction score 9,012 Location Ravenwood,MO Jan 19, 2016 #8 jmssaws said: Is a 2188 a 390xp with strange coverings? Click to expand... It is. I look forward to seeing this build.
Gunn Yay sawz Local time 6:24 AM User ID 529 Joined Jan 13, 2016 Messages 503 Reaction score 939 Location Plover wi Jan 19, 2016 #9 Yes @jmssaws
Redfin Meh... Local time 7:24 AM User ID 159 Joined Dec 24, 2015 Messages 7,653 Reaction score 40,039 Location Central Pa Jan 19, 2016 #10 Miller Mod Saws said: It is. I look forward to seeing this build. Click to expand... Me too. Gots a 2186 coming up soon.
jmssaws Banneded Local time 6:24 AM User ID 291 Joined Dec 28, 2015 Messages 10,024 Reaction score 37,296 Location Missouri Jan 19, 2016 #11 There is no such thing as a johnsred here,if I got it out people would run off in the woods screaming.
cgraham1 Here For The Long Haul! Local time 4:24 AM User ID 257 Joined Dec 26, 2015 Messages 4,707 Reaction score 20,312 Location Nor Cal Jan 19, 2016 #12 A ported 2188 is bad ass. Same as a 390xp.
tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #13 numbers without gasket .040 off the base, .060 off the flange numbers after base cut
tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #14 cut squish before sanding after sanding. very poor pic, much smother then it looks port map on sanding block
tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #15 only thing I did to the intake was match it to the boot
tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #16 exhaust port is angled to the side, I try to make it straight widened the exhaust port
tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #17 heat shield on cylinder heat shield on muffler matched port to sheild
tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #18
tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #19 need to clearance the case filler plate to clear the boot derco no gasket
tree monkey Mastermind Approved! Local time 6:24 AM User ID 339 Joined Dec 14, 2015 Messages 4,949 Reaction score 40,826 Location wi Jan 19, 2016 #20 side muffler port, nuts welded in heat shield on muffler matched
