MMWS MS660
GoBigBlue1984
Bluegrass Fart Knocker...
10:21 PM
Kentucky
Send me a message.......I gotta get some info from you.
I wish.........but this jug would not quite get there. 98 122 83
I stalked your old arborist site post on the 660 build Randy and used those numbers. Widened, raised transfers and it is spot on. By far my favorite saw to run. I hope to bring it with me in December. I ended up at 98/122/82
10:21 PM
What happened to the cylinders you helped design for the 660 Randy?
Would be nice to try one out with a good meteor piston.
Sent from my non internal combustion device.
There were some slight miscommunications as to whether this jug was going to be set up for an 064 with smaller 5mm bolts and a narrower bolt pattern, or on an 066 with larger bolts and bolt pattern. It's my understanding that the problem is being worked out and they'll be available soon.
The kits come with a nice looking Cross Performance piston (although I haven't weighed it or compared visually to an oem version) and Caber rings
smokey7
10:21 PM
Detroit
Holy chit 93* ex. Still the same duration?/timearea? That saw had to run funny..... or maybe they did something to to some other chit to make it run.....? Hell i am so lost.
Deets066
AKA Deetsey
10:21 PM
That's good to know Deets. How much did you take from the squish?
Squish was cut three different times, I don't recall the amount. I'm pretty sure the base had .072 taken off though.
Probly around 60 out of squish, the new piston also had a short crown height
Stihl working Hard
Is it Friday yet
10:21 AM
Perth Australia
the local ones have the new coils in them to have them running fatter.
That's correct Vince after updating my coil to the new one I was wondering what coil Stihl had put on them after they stopped selling them for a few weeks so I went down to my Stihl dealer and asked them to pull the pull start off surprisingly they did it's the same one I have put on mine and yes it's a little fat but it's safe.It runs better than it did before I just wish the Mtronic reacted a little quicker
Stihl working Hard
Is it Friday yet
10:21 AM
Perth Australia
Me either! Not the smoothest or fastest saw but dead nuts reliable & tough. After M/M ported mine & made the oiler somthing the EPA would cringe at, its place is safe in my stable. Much better than stock. I have resisted buying a 661 until a few factory upgrades have flushed away most of its bugs. They are close, but not quite there yet.
Couldn't agree more I haven't had an issue with my 660 it's only stock bar the factory MM .In saying that the 661 is an awesome saw yes it has issues with the Mtronic hopefully they can get it right bar that I have no dramas with the saw .
9:21 PM
They are supposed to be for sale at HL Supply in October. They will be available in both 064 base pattern, and 066.
The piston that comes with them is a very good looking piece. I think the exhaust ended up a little too square, but the two samples I saw had a very nice bevel, so that shouldn't be a problem. We left the exhaust port about stock width too, so ring wear should not be a issue.
jmssaws
Banneded
9:21 PM
It's a ks red light cylinder, 93 117 83
I have another red light cylinder that's
98 119 77
Crazy how much they vary
