- 8:54 PM
- Jan 28, 2016
- Dike, Iowa
You should have a 4 shoe clutch, it has two holes for a puller. Are you using a puller? Sometimes you have to wack the top of the puller to set her free! Also ditch the key on the clutch side! It can damage the crankGentleman, how to take the clutch off? I've loosen the nut, looks like a keyway slot on the spindle? But it aint coming off. Some heat?
It is a 4 shoes clutch. I didn't even know there's a puller for that. Didn't mess it with any force before asking you guys. The clutch has some oxidation, but not really rusty. Are there any threads on the clutch?You should have a 4 shoe clutch, it has two holes for a puller. Are you using a puller? Sometimes you have to wack the top of the puller to set her free! Also ditch the key on the clutch side! It can damage the crank
It’s on a tapper, like Jacob said they sometimes pop right off, and sometimes they need a puller, a steering wheel puller will work. I had an extra stubborn one, and it was difficult even with a puller!It is a 4 shoes clutch. I didn't even know there's a puller for that. Didn't mess it with any force before asking you guys. The clutch has some oxidation, but not really rusty. Are there any threads on the clutch?
This saw came from another fellow member, It's a very nice saw and runs great. Unfortunately the fuel
tank must have taken a hit and leaks. So i'm on the lookout for a fuel tank that will hopefully match the
rest of the saw.
View attachment 319749 View attachment 319750
What color air filter cover are you looking for?Lee, I have an extra SP125 fuel tank that is in good shape. It would be correct for your application, with the hole for carb adjustment except it was originally black and I feel would need a repaint. If you find you need it let me know.
Also, hope this is alright, but I am looking for a good condition rear cylinder shroud for a SP125C as well as the later model air cleaner cover that has the two stickers. I have two good condition, no cracks, etc. Early 125 air cleaner covers if someone wants to trade.
Mark, do you know if there are reprints of these anywhere for purchase?
Just a simple note guys, Be careful taping on the end of the crank on either the clutch side
or flywheel side as i had a welded crank weight come off doing so. Saw has a 101 in it and
i wanted to change the rim to 404 from 3/8, Tapped on the crank, Got the clutch off and
back on and the motor was locked up. Ran perfect prior. A welded weight had come off the
crank.
This is why I am getting them fully tig welded from thr get go! Cheap insurance, and if you add filler rod it helps smooth out on big boresJust a simple note guys, Be careful taping on the end of the crank on either the clutch side
crank.
