Mcculloch sp125/101b kart saw build thread
Bigmac
9:06 AM
Oregon
Gentleman, how to take the clutch off? I've loosen the nut, looks like a keyway slot on the spindle? But it aint coming off. Some heat?
You should have a 4 shoe clutch, it has two holes for a puller. Are you using a puller? Sometimes you have to wack the top of the puller to set her free! Also ditch the key on the clutch side! It can damage the crank
12:06 PM
I don't know about the cp 125 but the sp 125 did not have a keyway .It works like a Morse taper drill bit ,the taper holds it on .However it is a McCulloch so anything could be possible .You might try a few taps with a soft head dead blow hammer to pop it off .
jacob j.
Only the weird
9:06 AM
Coastal Oregon
Sometimes the clutch will just come off if you hold the clutch drum in your hand and tap the end of the crank with a brass hammer. I loosen the clutch nut and back it
out until the edge of the nut is flush with the end of the threads on the crank and then use a brass hammer.
Like Nathan mentioned - the clutch should have two holes also for a puller. If it's really on there due to corrosion, it may need some heat to work it loose.
qurotro
Cookie Cutter
11:06 AM
Ar
It is a 4 shoes clutch. I didn't even know there's a puller for that. Didn't mess it with any force before asking you guys. The clutch has some oxidation, but not really rusty. Are there any threads on the clutch?
Bigmac
9:06 AM
Oregon
It’s on a tapper, like Jacob said they sometimes pop right off, and sometimes they need a puller, a steering wheel puller will work. I had an extra stubborn one, and it was difficult even with a puller!
Scott Kelsey
11:06 AM
Wisconsin
This saw came from another fellow member, It's a very nice saw and runs great. Unfortunately the fuel
tank must have taken a hit and leaks. So i'm on the lookout for a fuel tank that will hopefully match the
rest of the saw.
View attachment 319749 View attachment 319750
Lee, I have an extra SP125 fuel tank that is in good shape. It would be correct for your application, with the hole for carb adjustment except it was originally black and I feel would need a repaint. If you find you need it let me know.
Also, hope this is alright, but I am looking for a good condition rear cylinder shroud for a SP125C as well as the later model air cleaner cover that has the two stickers. I have two good condition, no cracks, etc. Early 125 air cleaner covers if someone wants to trade.
Bigmac
9:06 AM
Oregon
What color air filter cover are you looking for?
Bigmac
9:06 AM
Oregon
Just spots this variation tonight( why saws should be inside!) 2 extra reinforcing rib on the chain brake cover! So there is at least 4 versions of the 125 cover!6E3B19C4-0BDE-423E-8776-091276052264.jpeg
So early and late style chain brake cover.
Looking back on @Lee H recent haul, the original chain brake saw has the early cover and other chain brake cover is late style and on a non chain brake model. All my saws are mutts so timeframe and originality is learned! Lol
Lee H
9:06 AM
cape cod ma.
Just a simple note guys, Be careful taping on the end of the crank on either the clutch side
or flywheel side as i had a welded crank weight come off doing so. Saw has a 101 in it and
i wanted to change the rim to 404 from 3/8, Tapped on the crank, Got the clutch off and
back on and the motor was locked up. Ran perfect prior. A welded weight had come off the
crank.
jacob j.
Only the weird
9:06 AM
Coastal Oregon
crank.
It's probably a good thing though Lee that it came off when it did, otherwise it probably would have come loose when the saw
was running and caused major damaged.
A lot of the kart guys have lost motors due to the crank weights letting loose at high speed.
Bigmac
9:06 AM
Oregon
crank.
This is why I am getting them fully tig welded from thr get go! Cheap insurance, and if you add filler rod it helps smooth out on big boresB9D3094C-1E5A-446E-82E2-5CCA7360D214.jpeg
heimannm
11:06 AM
Dike, Iowa
For anyone struggling to find the lower mount 85898 I made a post in the McCulloch Chainsaw thread...
Mark
