Makita 6421/7900 Runs Out Of Chain Adjustment
David _4
8:57 PM
SW Ohio
The above saw with a 28" Oregon Power Match 93 DL bar (280RNDD009) and Oregon 72APX 93 DL skip chain, but I have run out of adjustment with life left in the chain. I'm running a 7 tooth rim sprocket and I did verify the chain DL count. I usually run a 20" or 24" bar for firewood, but this summer I have been exclusively running a 28" due to bigger logs. This chain was new and the only chain I have run since the bar was new, any ideas?
dgb84
7:57 PM
NW Arkansas
It’s almost gotta be a worn sprocket or stretched chain. What does the sprocket look like ?
jacob j.
Only the weird
5:57 PM
Coastal Oregon
You probably just need to take a link out of the chain. A 93-driver chain is standard for a 28" bar on modern Husqvarnas, but I believe the 6401/7901 chassis
is just a bit shorter than the equivalent Husqvarna chassis' (365/372/385/390). When I was cutting with a 7900, I ran a 92 driver chain on a 28" bar and a
104 driver chain on a 32" bar (both Sugi-Hara bars).
David _4
8:57 PM
SW Ohio
The sprocket has plenty of life left in it. I would think that would be a lot of chain stretch
dgb84
7:57 PM
NW Arkansas
I’d surely trust ole Jacob J. He’s a pretty fart smeller. What I was thinking is that if your chain was a little sloppy and your sprocket was badly worn, it might not snug up enough.
I usually don’t know what the hell im talking about, so we will just add this to my file.
Lightning Performance
8:57 PM
East of Philly
My Makita saws will barely tighten a 93 dl with seven pin on a Total 28" D009 mount. Eight or nine pin is perfect as these fine gentleman stated above.
David _4
8:57 PM
SW Ohio
Thanks for the replies. I'll shorten the 93DL chains I have and buy 92DL's in the future.
Wood Doctor
Edwin
7:57 PM
Omaha, Nebraska
I like running a 92 DL chain loop on my 28" Stihl bar that I outfitted for my Makita. Same number of cutters on both sides (23) and no skips. My Echo CS-670 can also use the same loop with the same bar.
Hulsty
10:57 AM
As others above, I run 92DL on mine with 8pin, works well plenty of adjustment.
