Machining for port work
5:58 PM
I really need to send you a cylinder to cut the top off of easy
5:58 PM
A three phase converter is nothing more than a three phase motor with a couple of capacitors .Depending on the HP a couple hundred to say 1500 microfarad electrostatic start cap and 7.5 micofarad per HP oil cap for a run cap on 240 volt .They run at around 92 percent power factor .They will start up to the HP rating of the converter and run at about three times the rating .
Being some of what an electrical savant I have 200 amp single phase in my shop .With a 5 HP converter and some " creative" transformer wiring I have 240,480,208/365 Y, three phase ,265 single phase .
I've built maybe 15 or so converters over the years .The largest was 15-20 HP .
I have an air compressor I've been building with a 10 HP motor and a 15 HP for a converter .Back burner type of project .
Moparmyway
Its just a saw
5:58 PM
In a meeting
I got zero runout (using 0.0005 test indicator) on this one after I aligned the tailstock to the spindle. South Bend 9C-10JR, built in 1942
View attachment 13177 View attachment 13178
Things have progressed ........... added a QC, a few different chucks, a few different live centers, several different indexable cutters ................. etc
Moparmyway
Its just a saw
5:58 PM
In a meeting
Already have a ton of .250 burrs, but they don't fit the CC Specialties Rt Angle handpiece, so I grabbed a few sets of .125 burrs. A double cut set, a single cut set, and a diamond set for reverse direction with the Foredom TX. I'd like to get a longer cable thoughIMG_3809.JPG
lwhaples
5:58 PM
Vt
Nice box of bits! I hear ya on the cable length.
jmssaws
Banneded
4:58 PM
Mine is some kind of Hong Kong phooey
Type but I can't remember the name.
It's not old but definitely not made in America
