jb-chainsaws
I'd say that case looks almost as if it's been assembled from two separate saws, as I know at least with Stihl the case is machined after being closed, so that gap would worry me some?
To be honest several times I failed to do that ,forgot which corner. However as a result of same I became very adept at making gaskets so as not to have a head knocker.Chit happens .When I cut bases on a lathe I pick a corner to measure and use that one for the thickness taken off.
I always do an intake side corner near the clutch side. Saves the hassle of remembering nowTo be honest several times I failed to do that ,forgot which corner. However as a result of same I became very adept at making gaskets so as not to have a head knocker.Chit happens .
Very true. Anything under .015" with the small solder will read a lot thinner with plastigauge.Unless your using plastiguage your squish measurement will probably be off more than your machine work.
Check a few with solder then with plastiguage, your 020 can become 010
Even with that there's a difference. I've tried 3 different solder and the yellow plastigauge. Around .018-25 they read about the same.You have to use very small solder like 030 or less for it to be close.
I can take a fine point sharpie and scribe a line all the way around the base at 010 or 020 or whatever.
Make a mark and measure till it's right then use your finger as a stop and trace the edge.
Carpenters do it all the time
Friend of mine can draw a line in the middle of 2x4 that's better than a chalk line and faster.Yup. Amazing how accurate you can be with a little practice.
Mess with this stuff 50+ hours a week for years and you get a good eye for thousands.
I've measured with a caliper from the squish to the base, on 4 corners ............. the factory has ALOT more tolerance than I do.
Ragarding using solder for squish : If you keep rolling the piston back and forth over the solder untill you can barely feel it hitting, you'll get the same reading as plastigauge
This^
Last couple I have been using a piece of .015 pre squished solder.
That way I don't have to bolt the jug everytime. Just keep cutting/sanding the band until you can just feel it touch. Then check with fresh solder.
