Looking for Picco stuff.
Cracker Boy
Fl cracker
9:28 PM
Florida
@Icepick69. Will set you up its picco 3/8 ps he can also square grind it only true bar i know of to run it us cannon super mini s1 mount you will need 66 drive links for an 18 in bar on a p7 rim thats what i run on my 026 its a great setup if you do find a p8 you will need 67 links hope this helps.its the best picco chain there is i also run it on my 020t i velieve its 50 link not sure on that one.
Cracker Boy
Fl cracker
9:28 PM
Florida
He is also a cannon dealer and can set you up its a ps bar shop
BrokenSVT
9:28 PM
Georgetown, OH
I've got a 16" closed mount Stihl bar coming. Requires 60dl. I'm open to ordering chain from whoever can get it to me before Friday.
Cracker Boy
Fl cracker
9:28 PM
Florida
Is that Oregon drum still available?
Yes its same diameter as stihl drum but the splines are diff for the densco rim i had one i let it go with an oregon .325 rim stihl rim wont fit oregon drum
Cracker Boy
Fl cracker
9:28 PM
Florida
Yes its small spline oregon drum 7 spline but you have to buy danzco rims or oregon rims stihl rims dont fit spines are diff spacing
8:28 PM
Ok thanks
But still confused by this. Any part numbers?
Cracker Boy
Fl cracker
9:28 PM
Florida
Part number 100791 oregon Screenshot_2017-09-26-23-20-03.pngthen here is danzco 8 rim sprocket for that drum in picco to run 8 tooth in picco you will need 67 links on an 18 in picco bar might have to mod clutch cover some cannon super mini is what i run on my 026 hope it helps @Dub11
8:28 PM
Cracker Boy
Fl cracker
9:28 PM
Florida
There is a 9 and 10 pin on thebay to dave has remember for every rim size after 7 to add 1 drivelink icepick can make your chain and square frind it its bad azz chit
