T.Roller
- 10:12 AM
- May 11, 2016
- Southeast, TN
2100 crank in a 395
Yeah, I read through that, that is a neat build for sure
Does anybody know if the 394 crank can be pressed apart to have the rod and bearing changed?
Interesting, very interestingNot easily, but it can be done. Phil's saw shop in Florence, Oregon has one that they made a stroker crank out of.
What are those out of?
Yeah buddy! Sounds like a good build. Video required?I'm really liking the 372 Big bore with the 064 piston.seems like it has less torque than with the original piston but really flat out gets with it.
had to take out around 2mm out of the Meteor piston to make room for the wider connecting rod.after fitting in the cylinder and measuring the original piston i came up with only .001 clearance.so i spent another hour sanding the piston down to match the diameter of the old one.
also with the meteor the ring locating pins are too near the transfers on the intake side but are just right with the piston flipped around with the pins towards the exhaust.
letting it cool down now so i can take the muffler off to see if my sanding job was right.
