Let’s Talk 404
RI Chevy
1:40 PM
earth
Nice. You hand file square that chain?
What kind of rim sprocket is that?
Willard
12:40 PM
Manitoba
Yep hand file it, easy enough to do as the chain is already square ground chisel bit.
This chain from the 1970's has good consistent angles and a hell of a good honed edge right off the roll. Not like the un consistent cutter lengths etc. chain of today.
That's a Oregon 8 tooth .404 rim sprocket.
RI Chevy
1:40 PM
earth
Wow. They had square ground chain back in the 70's? I'm impressed.
RI Chevy
1:40 PM
earth
Interesting. I never ever knew that. I thought it was fairly a new concept.
RI Chevy
1:40 PM
earth
Cool. Never knew any of this.
morewood
Mr. Awesome
1:40 PM
Old Fort, NC
Got the chain from Madsens...27ax. I believe the saw could pull this cutter on full comp 36". Any way, going to need a longer bar for this oddball stuff, anybody know of a 50"+ ?
Mr Awesome
I can't afford a Cannon, not used enough to justify.
CR888
3:40 AM
Australia
I think there is a lot of truth to older chain being higher quality, not necessarily 'better' but it just appears more care was taken during its assembly, manufacture & factory grind. Perhaps today the top tier chain producers have so many cheap Asian imports to compete with, it don't help. But this is a trend that has happened with many products. I suppose though today consumers are better of in general buying chain though.
Willard
12:40 PM
Manitoba
In our Aussie hard woods they do but it is more than worth it for how much longer it stays sharp ....... I would like stihl to bring out a 3/8 chain with 404 size cutters .
Not sure about Stihl chain but about 10 years ago Oregon made a 3/8" chisel chain with heavier cutters like a .404 chain.
Was intended to cut a wider kerf in oversized softwood like cedar and fir.
7:40 PM
Do you feel That the saw had to work much harder compared to 3/8?
Yes, the PH is pulled down much more than with a very aggressive 3/8" chisel tooth same bar length same wood species.
But honestly, it could be due to the .404" being round tooth.
Getting a chisel tooth .404" for comparison would shed some light on this matter.
Homemade
1:40 PM
Wisconsin
So, why is .404 pretty much only in .063 gauge? I run everything 3/8 .050 and was thinking of converting a 20” bar (seeing how I have several) to .404 by changing the tip. This would be for playing with and having a super durable chain for stumping. But I can’t find hardly and .404 in .050 gauge.
I already have a bar in .404 x .058,and trying to find a chain for that is like looking for 1/2” pitch chain.
deye223
AIR FUEL SPARK VROOOOOM
3:40 AM
Australia
I tried a chisel 404 chain and it loads the saw even more as the Kerr is wider just wait till see how big the cutters are .
1:40 PM
Because it's a stronger chain made for larger saws and harvesters. A .063 drive link is considerably stronger than .050. And they say 063 carries oil better on longer bars
CR888
3:40 AM
Australia
They used to make 050 .404 I 'think', but nobody nowadays does anymore. For .404 .063 works well. I love cutting with a nice .404 chain, last week I noodled non stop 3 tanks of pine with my hopped up 660 & it was soft & fast. I was making some mulch for yard citrus trees & plant. After the chain was no where near blunt I touched it up on the grinder but it didn't really 'need' it.
Willard
12:40 PM
Manitoba
A Oregon field engineer once told me running a .063 chain is a perfect setup as bar's detachable sprocket noses are all .063
Running a .050 or .058 3/8 chain will wobble on a .063 sprocket nose. He said watching the chain cut with a slow motion camera shows a less efficient cutting action causing extra wear .
