Lets build a Husqvarna 262XP, SCARR style!
srcarr52
8:04 PM
Iowa City
I did some more testing with the saw over the weekend.
The timing light said there was around 25° so I put a little more to it. It will occasionally pull back a little on the rope now.
The cut times got worse, and tuning is harder to find the sweet spot. It lost 17% in the cut time. When I get a chance when it's not raining I'll go the other way with the timing.
srcarr52
8:04 PM
Iowa City
After going all over the place with ignition timing I landed back where I started. About 1/3 the keyway, 25 deg with my timing light.
I wanted more RPM in the cut so I tore it back down and raise the exhaust up some. Here is where I landed.
It's holding another 700 RPM or so in the cut, the cut times don't really show it being faster but I'm much happier with it.
srcarr52
8:04 PM
Iowa City
The inner and outer spikes came in from NZ. They are quite a bit bigger, but they don't use us a lot more bar. They are pretty thick, I won't be bending them!
And they match up very well. Now it feels like a 2 series!
srcarr52
8:04 PM
Iowa City
I do wish the studs were just a bit longer, with the outside spike on only 3/4 of the nut is threaded. It does make it hard to get the nuts started.
mojo Jojo
2:04 AM
slovenija
Hello, great build.
Since you use husky 262 piston...may I ask you to take some measurement of the piston.
The piston height is 1.635"... but I need a height from top of the pin to top of the piston, and a width of roller bearing shoulders.
What is the needle bearing size? ID/OD/W 12/15/13mm?
THX
Shane¹
8:04 PM
Kentucky
Hello, great build.
THX
Here is the specs from the metor book should give you measurements you need
