Lets build a Husqvarna 262XP, SCARR style!
srcarr52
11:33 AM
Iowa City
It popped and ran for a little bit but then all I could get was an occasional pop.
I guess I took enough out of the squish.
I just shopped around for a plug that was indexed correctly.
pbillyi69
8:33 AM
USA
which way do you want the plug indexed? with the gap toward the top of the chamber or towards the piston? or another way?
pbillyi69
8:33 AM
USA
looks like it runs pretty good. take another swipe off the rakers and see how it runs
Dolkitafreak
Dolkita686
11:33 AM
Central Ohio
Swap to a non protruding plug, easier than checking a bunch of different imo.
I’d like to see it with a little more exhaust and intake duration, 102-120-78 sounds feasible. Looks good as is.
11:33 AM
Sounds lean.
What’s were your final numbers?
It takes a lot to hit the plug on those. I’ve added a divot to the piston crown in the past for it, but I take less from the base now.
Much easier to assemble the entire intake tract onto the jug and then install in one fell swoop. I usually grind the case area where the intake partition drops. I don’t touch the rear pads anymore because I take less off the base.
The enemy of success is perfection. Looks pretty damn good to me.
srcarr52
11:33 AM
Iowa City
Sounds lean.
That's where it made the most power. Any more fuel and it would 4 stroke at 13.5-14 and not have as much grunt.
104/120/75
It's turning 10.8-11k in the cut. With the way everyone talked about these I expected more. I'll have to drop that bar and chain on another saw to get a better feel, it's a pretty hungry chain!
Hitting the plug isn't a big deal, that plug was indexed in the absolute worst position.
Parked on a shelf and run one of your 562s?
Possibly a bit more ignition, or fuel, see if it picks up with the fuel.
Or give it a bit more duration.
I don't have any 562's around but I feel they would have more power.
I plan to put a timing light on it and see where it's at. Probably add a little more to see if it likes it.
