JONSERED Jonsereds
Ronaldo
11:53 AM
Eastern Iowa
I’ve got two 50 cc saws set up with 3/8 on a 16” bar and I like em that way. A Dolmar 5105 and a Jonsered 2252. If the saw will pull it, I like 3/8 chain.
heimannm
11:53 AM
Dike, Iowa
Thanks to el33t I bought the LRB piston for the 451E, piston arrived yesterday so I put it back together today. Everything works just as it should.
This one came back with me from Oregon, I guess they had a "West Coast" muffler set up for these as well.
The 451EV I finished during the week had a completely different muffler with the square outlet.
Mark
heimannm
11:53 AM
Dike, Iowa
We also went through the 520SP today to prepare it for the display. I will have to say, compared to the 49SP this one is a lot more Semi and a lot less Pro...
The 520SP was dirty, but did have spark and adequate compression.
I should have taken a few more photos as we had this one down as far as the cylinder and spacer block off so I could replace the impulse line. The red silicone line just wasn't going to work out.
New fuel line, vent line, and impulse line. I went through the carburetor to be sure all was in order, in the end the 520SP is working as it should.
I realized as I was finishing up it is missing the brake handle and some bits under the clutch cover.
bucketoguts - this one is equipped with an 8T .325 sprocket and of course .325 pitch chain. I have not investigated much on these smaller Jonsereds saws but I haven't seen any full 3/8 pitch sprocket nose bar to fit, only 3/8 LP and .325.
Mark
ErnieG
12:53 PM
Northeast PA
Anyone know what these parts numbers fit ?
04420025
504420025
It's a piston and cylinder set
Thanks
Ernie
Serioussam
11:53 AM
North western Ontario
I just put the new decals on my 670 yardsale find
20250922_151737-jpg.470651
Jay Hansen
Foothills Vintage Saws
9:53 AM
Glide, Oregon
Cantdog
12:53 PM
Rockbound Coast of Maine
Generally speaking the 49/52 series came with the .325 X 8 setup. However the 52/52E and 521E frequently got changed to the 3/8 X 7 or 8 pin. Usually this was because they were limbing saws working along side a 621 or 70E felling saws running 3/8. This kept the files needed to carry to just one. The 49 could pull a 3/8 but was always happier running .325 X 8. Over the years and many of these 49SP saws I've acquired, many more burnt up ones were running 3/8 chains rather than .325. Most came with spur drive stock. I've changed every one out to rim drive. The only saw in the herd still sporting a spur drive is my hardly used 111S and there is a NOS drum with 3/8 and .404 rims for it sitting on the bench, waiting.
ray benson
11:53 AM
nw indiana
