JONSERED Jonsereds
edju1958
8:43 AM
Western N.Y.
Hey Cantdog,I messaged you back on March 4th about the woodruff key for the 49sp & never got an answer back.I hope all is well.
I tried filing a 1/2x1/8 woodruff key to fit as per Mark's instructions,but I'm running into an issue with the height of the key when it's in the slot.I'm afraid that if I file the height down too much it'll shear off.I'd appreciate it if you could send that key Kevin.Thanks!
Cantdog
8:43 AM
Rockbound Coast of Maine
Yep sorry about that. I have a pair of NOS keys for you sitting right here on my desk next to your address.....a new flywheel side key and the clutch spyder key.
Im a recent lung transplant recipient so don't seem to get stuff done as quick as I think I can. Back and forth to Boston a lot and a lot a rehab.......get pretty worn out by the end of the day but progressing in the right direction. I have your stuff and some items for Mark as well sitting here. I will get them out to both you guys the first of the week come hell or high water!!!:motorino:
zero_sum
8:43 AM
Vermont
Oh, wow Robin. I did not know that you have gone through that. I bet that takes everything out of you. Here's to a good recovery!
edju1958
8:43 AM
Western N.Y.
And here I thought you just plum forgot,sorry.I know what you're going through,I had an angiogram done on my heart last week & the doc found 2 minor blockages in the arteries,but not enough to warrant putting in stents (yet).He did find that one of the valves is calcified & needs to be replaced.I'm still waiting on getting an app't.for pre-op testing.It seems that they're really backed up here in the Buffalo area.Best of luck to you sir! You're not alone.
bulletpruf
2:43 PM
San Antonio, TX
Sending prayers!
sixonetonoffun
7:43 AM
MN
Put the 2065 on a Sugi diet. Save a whopping 10 Oz's!
Looks sexy. This is still my hardest worked saw. Runs an 8 pin sprocket yet ya could damn near stand on it without bogging it. I do have a jred sticker for the clutch cover just never seems to get there.
Woodslasher
Teh debil
5:43 AM
Commiefornia
At a neighbor's shop I stumbled across an 81 or 801 I've seen before but thought was long gone, complete with a full wrap and H & S spike if I saw right. I didn't dig it out from behind the pile it was behind to read the sticker, though, since it isn't mine. Next time I see him I'm gonna nag the owner about cutting it loose.
ErnieG
8:43 AM
Northeast PA
heimannm
7:43 AM
Dike, Iowa
The custom rear AV may just double the value of that saw Dan.
Last week a fellow walked in to my shop looking for some black iron carriage bolts for a spring board restoration project. As we got to visiting a bit I realized he was the Jonsereds dealer when I bought my first ever new saw, Jonsereds 621 in the fall of 1981...
I was able to locate some old carriage bolts and square nuts for him, in return he gave me this saw to do with as I wish.
The switches do not appear to be broken.
Mark
zero_sum
8:43 AM
Vermont
Mark
Nice! The red saws do have a tendency to breed. Heads up. lol
heimannm
7:43 AM
Dike, Iowa
I got a good start on cleaning up the 521E today. When the clutch popped off, it really popped... I learned a trick from cbfarmall, get one spring started in a shoe and clamp it in the vise as you work the other two into position.
Everything is looking pretty good, except for some of the wiring. I will have to deal with that as it is going back together.
Lately I have been letting the flywheels soak in my bucket of solution used for cleaning chains (Mean Green and water) and I am delighted in the way they come out without having to do a lot of scrubbing.
Mark
heimannm
7:43 AM
Dike, Iowa
What I mistook for compression turned out to be some drag in the starter and flywheel. Saw is now fully assembled but lacking adequate compression to start and run. I will have to look over the parts saws in the attic and see if I have one with decent compression and swap the top end over.
Mark
Jay Hansen
Foothills Vintage Saws
5:43 AM
Glide, Oregon
So, Mark, it just so happens that I have a 52e saw that was a good runner but developed a hole in the gas tank. I've robbed the ignition, but everything else is there. It appears to be a low use saw and has a bunch of pretty parts on it. I could send any or all of it, if it'll get your 521 project back on track.
