Jmssaws ms460
malk315
Running Saws for Therapy
7:28 PM
Lancaster, MA
Got a dyno graph for that 460 I believe and it said stock stihl numbers. 6hp at 9500 or something like that. Will have to get it on the dyno after it will be the first before/after specimen.
Sent from my XT1080 using Tapatalk
7:28 PM
What your trying new is more blowdown?
I've went from building short blow down saws to building saws with 23 to 26 degrees.
I think with the increase in intake duration you can put the increased bd to good use.
Yeah.....spot on. Higher transfers need short intake duration to build case pressure. If not, exhaust pressure overcomes the transfer charge. I'm seeing some real power increases with longer blowdown in the quad port saws.
Being injured is making me feel old.
Teach me guys.
I'm seeing it opposite from reading Bell's Book. I likely have it backwards.
Smaller case and less intake duration SHOULD cause higher case pressure enabling one to run a physically lower transfer (numerically higher). More intake duration should cause less case pressure and subsequently the need for physically higher transfers.
You guys know way more than me, that's for sure. I see the back filling as being an issue.
When I read about it, the real world experiences were with dirt bikes and not saws, but piston ported 2-strokes nonetheless. Regardless of exhaust height, they found that smaller cases caused so much transfer pressure that it was pushing unburned mix out of the exhaust. They started lowering the uppers to stop that from occurring.
Sounds like the transfers should work wherever they are cut then. Too high and they'll back stuff till they are ready, too low and they'll make more pressure and do more. Why move them at all?
Keith Gandy
Maxima K2 40:1 87 Pump Gas
6:28 PM
Provencal, Louisiana
Teach me guys.
Im lost! Wouldnt a longer intake fill the case until its greater than atmospheric psi then only result in spitback and especially if the transfers r smaller would even make it worse?
mdavlee
Hillbilly grinder
7:28 PM
TN
Teach me guys.
Moving them to raise the peak powerband if that's your goal. Some are just too low after machine work to gain compression.
