It's Stihl 044 time
redline4
I'm huge in Japan
7:04 PM
Rosholt Wisconsin
I cleaned up the AV stuff today.
I noticed the blue on a couple of the mounts when I took it apart but never looked closer, just thought they were aftermarket.
They are not. They are Stihl parts.
Is that something to do with this being an R model saw?
Canadian farm boy
“Normal” people scare me.
8:04 PM
Ontario, Canada
There’s 3 different AV mounts ranging in firmness. Iirc the blue AV mounts were the stiffest. R models typically came with them.
nixon
8:04 PM
West Sunbury ,Pa.
Thanks for doing this thread . I may be using this as a reference .A guy dropped off a ” stihl saw ,that runs but won’t idle . Well, it’s a 10mm 044 . Been abused badly. The PTO bearing let go and those pieces got eated in the cylinder . Piston’s toast , cylinder may make it . The owner isn’t really interested in putting anything into it , so I will make him an offer ( depends if the cylinder will be okay ) .
redline4
I'm huge in Japan
7:04 PM
Rosholt Wisconsin
After the tank has been sitting after I heated it and clamped it this entire time, I took the clamps off.
It straightened out pretty good.
I'd say if I were to put a rod or block in there and epoxy or plastic weld it, it would be more than serviceable.
That being said, there's still a bunch of breaks on this so it will be set in the spare parts box and I'll use a different tank.
