- 6:18 PM
- Dec 30, 2015
- Brewster, NY
T
Thanks for the detailed information Kevin. In theory, I agree with everything you say, but in actual testing on different saws, some seem to prefer one carb over another, and I can't explain why.
One of my ported 460s noticeably gained cut speed with an HD-50 carb, while my other two ported 460s did not like it at all, nor did my CFB Hybrid. I can not explain the results, I'm just saying what happed with timed cuts in Hickory that I conducted on my saws.
The hd50 has a main jet that delivers x amount of fuel at wfo regardless of the H screw setting. The H screw just adds a small amount of fuel to fine tune the high side. They deliver added fuel as soon as the jet is cracked open out to about 4 turns out. Drill the main jet too big and the saw will always 4 stroke even with the screws in tight. Drilling the jet or replacing it won’t give more power, it just gets you back inside the tuning range of the h screw, like somewhere between the preferred 1 and 2 turns out.
To get more power or rpm you’d need more air, as in bigger venture in the carb. Or create a controlled air leak somewhere if the carb can deliver enough fuel to support it
