is STIHL the only one doing 4-mix and how does that make more power than 2-stroke?
PissRev
4:38 PM
Ga
So you got a lemon that happens in all brands. It sucks but the 800 seems nice and my 600 is the first version still runs well. I like the high torque low noise of the 4-mix.
I had one of the first 90R trimmers that came out. I didn't like that it was either idling or wide open. There was really no in between. It was also heavier than an equivalent 2-stroke. I later got a FS11RX and it had more throttle control but I still don't like the 4-mix. I'm glad you do like yours though.
lehman live edge slab
Live Action
3:38 PM
Mn
Guess I’ve never seen a point to run a saw, leaf blower or trimmer at anything but wide open or idle but to each their own. I don’t run my fs 56 2-mix or my br 350 2-mix at anything other than wide open while working or idle between spots because that’s how they were made to run.
PissRev
4:38 PM
Ga
When you're trimming and there's windows 2 ft off the ground, or you're trimming around vehicles, you definitely don't want to run that thing wide open.
RCBS
Redneck Savant Extraordinaire
4:38 PM
Ohio - The hilly part
I get folks who tell me this about skidsteers and CTL's all the time. My question: Why is the throttle 'adjustable' if they are meant to run wfo all the time?
Traprunner
4:38 PM
Maine
Only Stihl's i own. Bought a 600 and a km110r back in the mid 2000's or so and used for 10 years commercial use only problems with trimmer was a few throttle cables. Not one problem with blower that I still use almost daily to blow sawdust offen sawmill at the end of the Day.(might take 2 minutes).It only gets warmed up twice a year doing yard work or when burning a brush pile. Adjusted valves In trimmer I think once. At the time of purchase I had a jonsered trimmer that i wasn't happy with for the application. Just my experience with the 4mix.
HokieJoe
Active OPE Member
4:38 PM
Virginia
Yeah, I can't speak to the BR800 issues, but I'm telling you my KM131 purrs. And it's easier to start dead cold than 2-cycle engines imo. And they're relatively quiet. That said, I understand why people don't like them with occasional valve adjustments. I can only speak to my experience, and it's been great so far.
I still love the sound of a screaming 2 cycle though. I used to envy the go-karter's who raced them. I was in the 4 stroke class. Klotz and methanol!
lilspenny
OPE Member
3:38 PM
They did! MSRP is surprisingly low compared to 2-stroke models.
Actually, Echo just revived this with their new 5810 blowers. They are a real powerhouse compared to the 580, which they replace and were no slouch themselv
Actually, Echo just revived this with their new 5810 blowers. They are a real powerhouse compared to the 580, which they replace and were no slouch themselves.
Oh no! The sky is falling!
hacskaroly
2100 Fanclub Member
1:38 PM
Northern Idaho, Ehh
I had a friend bring over his FS90, runs great for about 3-4 minutes and then dies out. Tested the valves and they were loose. Adjusted them a little tighter with a feeler gauge and it runs without issues now. Adjusting the valves is one of the simplest things I have done on OPE.
FergusonTO35
4:38 PM
Boonesborough, KY
My 4mix FS-91 is just fantastic. My only gripe is it constantly bounces off the rev limiter at WOT. I need to figure out how to put the cruise control on it like the more expensive ones have.
lilspenny
OPE Member
3:38 PM
Some people see it as a boring task, but others enjoy the smell, the sound, the machine in action, and the artistry that goes along with a job that is done to near perfection.
EFSM
3:38 PM
Extreme southern IL
I think the tigger has an adjustment screw in it on that model. Backing that out a couple turns means the throttle cable won’t pull as far, which of course will limit power, but it should mitigate the rev limiter use.
