Pioneer
Old Saw
- 12:10 AM
- Jan 24, 2019
- Kamloops BC Canada
Had to put this together to see how it looked. Not sure about the color, a good match for the faded Red so it can stay the way it is.View attachment 256641
Cylinder looks good inside
as does the piston both through outlet and inlet port.
Clinder head looks as if it has taken some major impacts. No match for the traces at the piston.
May the piston has been replaced in the past and the head left as is?
4241 or 42 ignition?
Cool finds for sure. Is the p65 a boost port top end?Look what i found today. Wonder what it is worth?? I also found a nos p65 cylinder and piston kit with rings. A new p52 case and another half recoil side.
Tell? Have the extra ports on the bottom like the p42?Cool finds for sure. Is the p65 a boost port top end?
The last picture you posted is a boost port. Measure the bore of that cylinder.Pics of the p52. I have to go back and get the p65. Is the boost port the recessed part in the cylinder wall??
Its a p52 boost port then. The p65 is also a boost port. Thats awesomeThe last picture you posted is a boost port. Measure the bore of that cylinder.
