HUSQVARNA HUSQVARNA THREAD
Sloughfoot
6:01 AM
Norcal
No base gasket was:
106 ex
Transfers open 123
Intake 74
Thought to take 20/30 thou of both base and squish and finish exhaust at 104
Put transfers back to 17 BD
Widen intake a hair.
Good bad or ugly? 🙃
Transfers may be better where they're at after you raise exhaust to 104. Were mine, I'd run it that way before putting them back and see.
I'd most definitely advance timing with the base cut. Probably lower intake a couple degrees too.
Shane¹
9:01 AM
Kentucky
Hello All.
Rebuilding a 357xp now with intention to port.
With no base gasket squish is 20 tho.
Whats reccomenation on amont to machine on this model?
Was thinking to take 30 tho of both base and squish or is this excessive?
Cheers
These are the numbers Randy suggested I use and I would trust his numbers. Hope it was ok to share those @Mastermind
.035 from the squish, .032 from the base. No base gasket.
Ex: 100
Tr: 120
In: 83
Ex port width 1.410"
Advance ignition timing.
Sloughfoot
6:01 AM
Norcal
Ex: 100
Tr: 120
In: 83
This is all you need to know. May look like an extreme change to intake and blowdown, but know it isn't. Considering the source, these are work saw numbers not race saw.
eric4
6:01 AM
Northern CA
How lucky am I, to have snagged a 372xp and 395xp which looked quite clean and complete...
Just to find (at least) 8 stripped bolts in the cases. The 372 had all four recoil bolts stripped or jammed with a broken screw. My 395 case had lag bolts ran into the top cover, and a stripped screw that holds the air tunnel behind the flywheel. Of course none of these problems were mentioned in the listing :)
Some of these with blocked holes and screws, are near impossible to drill out. The broken off screws are hard as hell, and have my drill bits skating atop.
My plan is to fill them with JB weld, and then helicoil them to the proper thread. Wish me luck!
SimonHS
1:01 PM
Yorkshire, England
It helps if you can get the broken bolts square under a drill press. And use a deep centre punch mark. These two things stop the drill bit skating about. Then, if you can run your drill anticlockwise, you need short left-hand drill bits. If you are lucky these work like extractors, and sometimes will rotate the broken bolts out.
eric4
6:01 AM
Northern CA
Thanks for the recommendation! My current left hand bits I've been using are quite cheap, so I've got some nice cobalt ones showing up today.
SimonHS
1:01 PM
Yorkshire, England
Another thing to try is heating the broken bolt with a soldering iron. A few heating/cooling cycles might help loosen things. To get them really hot, without damaging the case, you can heat a steel rod with a gas torch and then put the hot end of the rod on the bolt.
singinwoodwackr
7:01 AM
moon
Solid carbide drill bits…get some. They are brittle and can break if tweaked at all but…can drill out a broken tap, easily. They are pretty much a drill press only deal, however.
lehman live edge slab
Live Action
8:01 AM
Mn
Now then the 450 Husky Rancher I've been tinkering with .The original complaint was it didn't oil which it did without the bar and chain ,just not much .In testing it the damned thing it didn't produce enough power to run a pizz ants motor scooter .Carb was off ,factory setting .I ordered a set of those funky carb tools and that should do it .
It only makes sense if the engine won't rev it won't pump oil very well .Probably a box store saw that was never tested before it was sold .
I’ve seen so many issues with the 450 that anyone asking about them I tell them to not bother. Where my wife used to work they had 2-3 in at all times anything from flywheels that sheared keys and went out of time to major air leaks at multiple places. They are a complete turd wirh too small of a carb to feed them correctly and as weak as a lot of people think the ms 271 is they stomp a 450 pretty bad and wake up to a muffler mod as timing advance very well.
9:01 AM
Actually I've got the thing running fairly well .The deal is the owner belongs to a so called property owners association near Columbus Ohio .Uses the saw for some path clearing work on woods trails .In other words it's country club saw . He probably would have been better off to have bought a battery saw . Nice guy but doesn't know his azz from a hole in the ground about chainsaws .Does have a couple of nice 57 Chevys that he doesn't work on himelf . I get stuff like this all the time .They screw it up and I fix it .
Olds120
9:01 AM
New Jersey
Picked this up today for $60 from a guy at hunting camp. Starts runs but low compression. Will see whats what when I get home.
Sloughfoot
6:01 AM
Norcal
Got this brake in the mail today and feel like it's missing something. All new to me and can't make heads or tails out of the IPL. What's in the pic is all it came with.
hacskaroly
2100 Fanclub Member
6:01 AM
Northern Idaho, Ehh
Looks like it is missing 501 41 90-01. Not sure what that little forked pin is for unless it is supposed to be 501 41 90-01, but it looks a bit thin to take on that role, I would expect a thicker pin there.
