HUSQVARNA HUSQVARNA THREAD
el33t
9:30 PM
Poland
Matter of fact, I encountered this very problem on my new to me MS-194C yesterday. It would die out after a long cut. I richened the low side a wee bit and reset the idle speed screw according to factory instructions: turn it in until the chain turns, turn back out until chain stops, turn back out one full turn. It now returns to idle just fine, although it sounds fast to my ears. Stihl doesn't publish a spec for what the final idle speed should be on this saw, as long as it runs well I'm going to leave it as is. I suspect it may be able to idle down more as it breaks in, I honestly believe this saw still had dealership fuel in the tank when I bought it.
Officially, the idle speed for MS 194 is 3000 rpm.
I think it is unlikely that enriching the idle mixture with the L screw helps in such cases. The mixture for low revs is adjusted in such a way as to achieve satisfactory acceleration, i.e. on the rich side of “optimum” (when the idle speed reaches its maximum). It is much more likely for carburetors with an independent idle system that after closing the throttle, the mixture will be too rich, causing the speed to drop below the speed at which the engine will stall.
If you enrich the mixture with the L screw, the engine speed drops instead of increasing. Assuming, of course, that the factory settings are reasonably correct (on the rich side of the "optimum").
When the idle mixture is leaner than recommended by the manufacturer, the engine speed does not drop as quickly and a situation can occur where in the case of chainsaws, after closing the throttle, the speed is still higher than the clutch engagement speed for a moment.
In summary, in such cases, when the chainsaw is in working order, it is sufficient to increase the idle speed in accordance with the instructions by using the idle speed screw, finding the speed at which the clutch engages, and then reducing the speed by one turn of the screw in the case of the MS 194 (this varies for different models). The procedure for adjusting the idle speed is included in the manuals of most chainsaws, as problems with this are common. See, for example, this recent thread:
According to standards, for safety reasons, the clutch engagement speed should be at least 25% higher than the idle speed. So if you set the idle speed to 3000 rpm, the clutch should engage at 3750 rpm at the earliest.
FergusonTO35
3:30 PM
Boonesborough, KY
Thanks. According to my manual, it gives the idle speed after factory carburetor adjustment of the hi/lo screws as 3000 rpm but it doesn't give a spec after adjusting the idle stop. It just says one full turn out after the chain stops turning. I'll check it with my tach the next time I cut with it.
el33t
9:30 PM
Poland
The exact idle speed is not that important. According to manufacturers, the most common tolerance for its setting is ±200 rpm, which means that anything between 2800 and 3200 rpm is acceptable in the case of MS 194.
The idle speeds required by them, as I wrote in my previous message, are due to safety reasons and, of course, fuel consumption (which is not always so obvious).
In the old days, the idle speed was often set to a value just below the clutch engagement point. This ensured the fastest possible acceleration to full throttle. Of course, it should be added that rpms were lower than today, and clutches (in chainsaws) were usually equipped with linings.
FergusonTO35
3:30 PM
Boonesborough, KY
I checked it with my tach today, and she is doing around 3000 at idle and 12600 WOT. So, I guess I am in good shape. The 194 manual says it is rev limited to 13k. When I first got the saw you could pull the trigger and hear it bounce off the limiter. I removed the carb limiters and fattened up the fuel just a little bit, now it doesn't hit the limiter from what I can tell.
lehman live edge slab
Live Action
2:30 PM
Mn
Definitely a tune in cut saw
Live Action
2:30 PM
Mn
Ive noticed a lot of people looking for 357/359 saws and parts, they really getting that hard to find or is it just a lack of cheap parts available for people to buy?
oddsaws
2:30 PM
Bartlett TN
In my recent experience there still seems to be a lot of 359s out there for sale. For the 357 I have only found crankcases without the cylinder and the cylinder seems rare to find used. New cylinders are up there in price and there aren't many out there.
Live Action
2:30 PM
Mn
Ok I have a 357xp at home and was just wondering. It’s blown but I’m sure the jug will be fine just needs rebuilt with new piston and bearings/seals.
heimannm
2:30 PM
Dike, Iowa
Customer brought in a 66 (not a 266) with no spark. I checked the coil and I believe it tests good, any ideas on where to find the electronic trigger unit? Were there other saws with the same set up?
Thanks,
Mark
Live Action
2:30 PM
Mn
Thanks,
Mark
Only place I’ve seen 2 pc ignitions is used ones or the China made 2 pc for the 61’s ect and unfortunately the couple I tried didn’t last
el33t
9:30 PM
Poland
They are China made anyway.
Ebay 501 51 61-02
heimannm
2:30 PM
Dike, Iowa
I have the ignition module for the 66 on order from Sawzilla, we'll see if/how long it will work.
Next challenge...I picked up a few more saws on Saturday including this 480 CD. My plan is to get it cleaned up and operational if possible then put it in the display. I'd like to find a better top cover if possible. Suggestions. recommendations on where to find a cover?
Mark
hacskaroly
2100 Fanclub Member
12:30 PM
Northern Idaho, Ehh
Unless someone has one stashed away, eBay will probably be the best bet. I had to be vigilant and watch for my 2100cd cover and ended up getting a second one because it was in better shape than the first one I got.
3:30 PM
I got a pleasant surprise today ,Husqvarna 240 with a bad coil ,simple .I tested it out and for a little guy this thing really surprised me .For 38 cc's it cuts like a true three cuber .Filled a garden cart in about 10--12 minutes with 6 inch wind blown stuff .Not bad for an old coot . After market coil made exactly like OEM--China
Maintenance Chief
3:30 PM
South Carolina
I rebuilt a 365 special a while back , seems to want to die down when tipped nose down? Any ideas?
jacktheripper
Papa Squat
1:30 PM
Wyoming
Could be a cylinder base or intake leak that’s temporarily acting different because of puddling fuel. Could also be carb metering.
