Husqvarna 579xp
NPKenny
11:29 PM
Lehi, AZ
Fun project. I'm glad you have the personality to accept / appreciate the failures that precede success.
What is the liner material? Is it a cast iron bore now?
Maintenance Chief
2:29 AM
South Carolina
I watched the breakin video and didn't think it ran bad? Almost 5ft lbs of torque ain't too shabby!
I imagine that lossing some HP out of the base didn't help.
I'm just seriously impressed with the process of sleeving the cylinder. I imagine that you could turn an open port jug into a closed port with a sleeve?
Red97
2:29 AM
MI
Ok, a bit more better....
Same 565 and ported 572 runs.
Round 3, (2nd time on dyno)
Pink line is right off the bench.
Light blue is a bit of timing advance.
Remove the filter, and power stays the same, wonder what will happen if I swapped a 572 carb on? Or is it possible to flash a 572 firmware onto This?
Table flat powerband, but won't reach up...
Could be the porting, and may still need to seat in.
Leaving it as is till after Kevin's gtg. Let people run the snot out of it or burn it up, whichever comes first.
Discuss? I'd love to hear some thoughts and opinions.........
K thanks
Woodpecker
Sassy Madam
2:29 AM
K thanks
You gonna make it to Kevin’s this year bud?
Stevetheboatguy
1:29 AM
Nw IL
K thanks
Have you played with the ign timing any? Or air gap on the coil?
Steven
gurwald
8:29 AM
Sweden
Any reason you picked a 565 over a 572 to mod?
Im not sure what the difference are other than more restrictive transfere caps?
