- 6:30 AM
- Dec 29, 2015
- Ontario, Canada
You read my mind on the carb update. Sounds like a typical bog for that old carb.
@M2theB , to see if your carb hasn’t been updated remove it, flip it upside down so you’re looking at the metering cover that says Walbro on it. You will see 2 gaskets tabs sticking out from under the cover near one of the corners, if you see a blue tab it hasn’t been updated. You’ll also want to drill a hole in the pump diaphragm cover to vent it. I’ve never watched Scott’s video on updating them but I’m sure that step is in there.
What do you think?
I don't see blue.
Pull the cover and drill a hole like the Zama's have?
Did you check the metering lever height? It should be level with the carb body, too low and it will not get enough fuel, too high and it will flood.View attachment 131776 View attachment 131771 View attachment 131772
I had another 199 on the bench from the previous saw, and it's easy to notice the blue.
Popped the cover and put the hole in it.
Saw starts really well.
I liked the idle at first, but it crept up. Chains not spinning, so its not that bad.
But it still has a case of the bog at 1/4 throttle. But it'll push right through it when fully goosed.
Not sure a was supposed to see wet though on that side of the diaphragm.
No need to buy a new lever if the adjustment is off, simply bend it to the correct setting.I didn't check that. Although the video said I should.
If I had checked it and it was too low or too high, what the next step be? New lever?
A little more information; when I put the saw back together I noticed the left carb through bolt was stripped, but still gave some torque resistance. So this afternoon I gave the assembly a carb cleaner spray test at the joints. I was able to stall it at the carb to flange joint. That's a known item that won't get any better with time and is on the parts list.
Compression is low, 125ish, and if a new flange doesn't fix that I think I'm heading into a full leak check, possibly replacing the shaft seals.
The saw isn't a virgin. It's a project.
Thanks for the help.
Yes sir they sure do strip if one were to “white knuckle” tighten them. Very good point that I neglected to bring up...That plastic “coller” was striped out on mine on one side. If a guy gets too torque happy they strip easily. I bought a new one and was careful tightening it up.
A bad carb mount is certainly an issue and I would definitely replace the flange collar, good catch.
125psi is a little on the low side in my opinion...did you already put a new ring on it?? If not I would if it were my saw, Caber rings are good quality and inexpensive. A new ring would bring you up to about 150psi. Delete the base gasket and you’ll see about 175psi
Sounds like you’re nailing down all the little things adding up to why the saw isn’t running 100%. You’ll be very happy when you get it dialed in, love me some 359.
