ZukiRyder400
Breaker of recoils
- 10:04 AM
- Apr 11, 2018
- Your bum
I have been some crazy ideas lately... this is one of them... Husqvarna 372 crank in a 357/359 chassis. BUT... I have a lot to figure out before I can start tinkering..
1- Is there enough material on the cases to bore out the existing bearing pockets to accept the 372 crank bearings?
2- Width of the crank (outside of lobe to outside of lobe)
3- How much bigger are the lobes on a 372 crank
4- Is there enough meat in the case around the 359/357 crank to make the pocket bigger? If not, maybe beef it up with some welding and mill it flat.
5- Spacer thickness (if I need one, that will come later)
6- Measure the inside + outside diameter of the 359 and 372 seals so I get an idea of what material needs to be removed.
Still a lot more things to figure out...
