- 1:08 PM
- Feb 10, 2016
- lincolnton nc
AS ALWAYS JOE BADASS POST!!!!!!!!
Right?!? Lots of oracles in this thread and Joe is one of them for sureAS ALWAYS JOE BADASS POST!!!!!!!!
Used 1184 threebond on my 385/390 vent. Hasn’t leaked yet and can be removed if need be in future.Another good chunk of quality info, Joe. And Bob's input on the early 357 cranks is certainly good to know as well!
Slightly off topic as it applies to several Huskys in general, but is there a preferred sealant to use for a leak around the tank vent? I have a 357xp with a very annoying leak at the vent location. Not the vent or the vent line, but between the vent and the tank. Seems like a snug enuff fit but still leaks. My normal sealant of choice is Dirko but I don't know how it would hold up against direct contact with fuel. Have had mixed results in the past with Seal-All. Don't want to use glue in case the vent needs replaced some day.
It's nothing I couldn't live with myself, but it's a customer's saw so I'd like to tighten it up and not have it come back leaking again.
I have done this to both of mine.View attachment 123622
Remove the old tensioner and discard it.
Reinstall the bar pad plate and wind the worm gear in.
Drop the needle bearing and clutch drum back on.
Grease the bearing.
And spin the clutch back on.
View attachment 127552 View attachment 127553 View attachment 127554 View attachment 127555 View attachment 127556 Joe
Great post! I picked this guy up about a month ago and have been picking at it since.
Nice project on the bench and your post is an awesome reference!
And that's all it came with.Holy *s-word that thing is dirty!
View attachment 127557 View attachment 127558 Got it running with a 357xp top last weekend, but still has some issue.
Got it a bar and chain to celebrate and provide some encouragement
ThanksLooks good now.
Looks like an OEM 359 cylinder too me. Good catch on the intake clamp and pulse grommet.I posted this question on the Husqvarna Thread yesterday but it really should have been here. Sorry if this is redundant.
I got this 359 project saw, a different one than the one in the above posts. At minimum needed the plastic clip at the inlet port modified to the metal band. While I had it apart I saw that the cylinder part number closely matches that of 361 through 372 series saw. It measured about 47mm. (When I say closely, it was missing a "93")
The saw is a 2005.
It ran with the cylinder, but not well. It stalled out when I pointed it down, but I attributed that to the loose boot and as it turned out, a broken impulse nipple on the partion wall.
Does a 503 93 72 make sense on a 359?
The cylinder does have the Husky crown on it, so I'm confident it's OEM.View attachment 131613View attachment 131614View attachment 131615View attachment 131616
