smokey7
- 11:58 AM
- Feb 3, 2016
- Detroit
Dad bought it new only used xp oil. Ran for a few tanks, it screamed. We called the dealer and they said they did first start and tuned it. They said it was just a high revving saw different then the 3400 he came from. Ran for a couple more tanks and she started rattling bad and locked up tight. Dealer said strait gas and no warranty. Then dad called husky corporate and leveraged a warranty. Sent it back to selling dealer for a rebuild. New p&c crank and seals. Got it back rattled terrible like a bad crank and or loose clutch. Found riser bolts loose and tightnesed up and clutch missing washers. But it ran good now. Ran for 10 cords for season. Pulled out next year, ran for 1 tank and seized again. Called corporate got another warranty authorization to repair at a different dealer. He found a very old crank seals and rtv on the riser and cylinder. And a bad rod bearing. Rebuilt again with another crank and top end. This time we saw the old parts. It ran for about 6+years but still rattled bad and had low comp, and very cold blooded . It finally lost all comp. I tore it down and found a 44mm piston in a 44.3 bore. Tons of transfer and a wiped out cylinder. I'm guessing that both dealers used the wrong piston and cylinder combos and shoddy work killed it. This time she will be done by me and will be right.
