- 8:49 PM
- Jan 8, 2016
- Farmington, CT
Honestly....I don't want to grind on that new hyway cylinder. ...the plating is too pretty hehe
You need any machining Al, send it on down here. I'll take care of it for ya buddy.I'm gonna try to get to mine before the GTG Matty.
I'll be bothering you on the phone a bunch.
I'm gonna need to make a 44.3mm mandrel, or figure out how to machine that riser.
Thank you.You need any machining Al, send it on down here. I'll take care of it for ya buddy.
It's the least I could do Ben.I may get you to do one for me before too long Brett.
Sent from my HTC One using Tapatalk
Did I miss the point. Inquiring minds want to know.Far as I can see...no point in the kafar kit. UK kit is similar...cheap. ..better cast and more complete. I'll be grinding on this one today.
But...oem isn't much more expensive.
Interesting. ...I think there IS a point to buying the hyway kit. But I'll share that at the gtg. When we do the comparison. ...people won't be able to tell which saw is which by the lookswe will run them....then talk about which is which after
Ok.you are probably better with oem from a price standpoint too... 105 shipped from Spike60 last I checked.
I think hyway ported, without squish cut is great and what I use, but stock oem, or ported squish cut oem is the way to go
