Husqvarna 350/346 Repair Thread.
psuiewalsh
Basement Bodging
12:47 AM
Nottingham,pa
What is the proper way to run a rim sprocket on the 350 I bought the drum kit and oiler worm for a 346. The crank is larger od on the 346 where the worm rides. It is sloppy on the 350. Is there a bushing? I have the spur oiler worm on it now but it is not a tight fit to the drum ribs.
Onan18
OPE Sponsor
12:47 AM
Georgia
I just buy the Oregon Powermate rim setup for a given model, they work very well.
psuiewalsh
Basement Bodging
12:47 AM
Nottingham,pa
How does that work with the oilers worm? Does it have the spur type ribs on the spline drum?
psuiewalsh
Basement Bodging
12:47 AM
Nottingham,pa
Looks like it could be 1/2" id bushing, .585" od, .340" long. There is also a difference in thread length as the 350 worm is deeper. Not sure if a washer would put the worm in a bad place on the oilers?
psuiewalsh
Basement Bodging
12:47 AM
Nottingham,pa
Sounds like a good aftermarket worm upgrade. If they could machine the core in the mold to fit the spline drum on the spur oiler mold.
decableguy2000
12:47 AM
WNC
Trying again with a problem child 350. I have had issues with sealing the case and bearing cup. Just installed new bearings and seals tonight. Will P&V tomorrow evening.
Dawnsman
12:47 AM
USA
So my question is how to turn my 350 into the 346xp
Sent from my VS425PP using Tapatalk
Tor R
Novice, Leg model #2
6:47 AM
Mandal
you need to buy the worm gear for the 350 Keith.
M2theB
12:47 AM
Central Mass
Looking for some assistance. I put a 346xp, OEM, p/c on my 2007 353. Same time I change the rubber/plastic from the carb to the port inlet.
I can't get this thing to idle. Right now I have adjustment all the way closed and it works best like that, but I still have to feather the throttle to keep it running, until good and hot. Any adjustment to the right and the saw will die quicker. Was there an ignition or carb change I should have made too?
Onan18
OPE Sponsor
12:47 AM
Georgia
Pulse line have a hole in it, or possibly pinched?
