- 7:49 PM
- Jan 8, 2016
- Mandal
its the 503 27 40 01, right?50327001. It is the larger of the 2 they offer and requires a 7.1mm drill bit
The 44mm cylinder that's on this saw is IMO a much better top end than the capped port jug on the later 350's and 353's. Mentally I know it's hard for some guys to like open ports, and you can "do more" to the later cylinder. But we're talking a Husky 350 here. The 44 runs great with a gasket delete and muff mod, and you don't have to replace the dished piston. But the real negative with the later jug is that there was some kind of harmonic vibration that caused them to spit out the muffler bolts. It was a problem with both the 350/2150 and 353/2152. Worse on the plastic saws, as people would run them with a loose muffler and the exhaust gases would melt a hole into the case. "Hey my saw has an oil leak." Lowering the RPM's to the low 12's actually made a difference, but I doubt that idea would play well on this site. Do you guys get the impression that I don't like the 45mm jug all that much?JUNK!
Some other random points:
351's: These saws should all have the 44mm jug. But the last few of them came in with 353 top ends before the official model change over.
There are 2 different starter pulleys/springs. The early saws used smaller ones that were also used on some trimmers. (and still are). The later ones used a larger pulley and spring, that is still used on the 445/450. You can SOMETIMES tell visually which is which. All starter housings that were given additional ribs to keep wood chips from entering the starter, have the larger pulley/spring. But the change to the internals took place about 2 years prior to the housing change. Good to know this stuff when ordering parts as if you just ask for a 350 starter spring, you want to get the right one.
The changeover from course threads to fine threads on most hardware took place at about the same time as on the 357/359 family. 2002/2003 or whatever.
The early metal cased saws also had the twist on air filter before the switch was made to the clip on filter. If you guys are wondering how I know all this stuff, this one was learned years ago by selling someone the wrong filter and having him come back pissed off
Fun stuff: There were actually G models of the metal case open port saws. 351/2149 as well as the 353/2152. These would have to be the rarest models in the series out there, especially the Husky versions, cause most G models would be 346's. The Jonsered 2147 was never imported to the US, so they made due with the 2149/2152 as their pro saws until the 2153 was released. I have a buddy that has a 2149WH. So, heated grips on any of those models would be a rare find.
I'e never picked up one 351/G saw in Southern Norway, seems they mostly sold 346xpg here.The 44mm cylinder that's on this saw is IMO a much better top end than the capped port jug on the later 350's and 353's. Mentally I know it's hard for some guys to like open ports, and you can "do more" to the later cylinder. But we're talking a Husky 350 here. The 44 runs great with a gasket delete and muff mod, and you don't have to replace the dished piston. But the real negative with the later jug is that there was some kind of harmonic vibration that caused them to spit out the muffler bolts. It was a problem with both the 350/2150 and 353/2152. Worse on the plastic saws, as people would run them with a loose muffler and the exhaust gases would melt a hole into the case. "Hey my saw has an oil leak." Lowering the RPM's to the low 12's actually made a difference, but I doubt that idea would play well on this site. Do you guys get the impression that I don't like the 45mm jug all that much?JUNK!
