Husqvarna 281xp
idiotwithasaw
2:18 PM
Ky
Ok, so it appears that my rubber I was using to block the exhaust side was leaking into the muffler. I don't have any more innertube rubber, i have no idea why, I should have at least one bad tube but none to be seen.
While I had the tank off I checked the jury rigged fuel lime and grommet. Turns out either the fuel lime he used was too big or the grommet was too small. I couldn't blow any air through it. So I think that was my problem all along. So I am gonna just rebuild the carb, replace the fuel lime with a smaller one and reassemble it and try again.
idiotwithasaw
2:18 PM
Ky
Update, rebuilt the carb, But I tore the grommet. I'm going to have to figure something out before I put the tank back on.
Sent from my HTC One using Tapatalk
psuiewalsh
Basement Bodging
3:18 PM
Nottingham,pa
That would work too as long as you can get it to seal on the carb hose barb and fuel filter. Sometimes you can get away with a stihl filter, they are larger barbed.
rattler
3:18 PM
NC
That is how my old 181 was.
idiotwithasaw
2:18 PM
Ky
I considered the larger hose, I also thought about using shrink wrap to build it up, but I'm not sure that's fuel resistant. I need a bigger supply of fuel line. The hole really isn't that big once I pulled the grommet.
idiotwithasaw
2:18 PM
Ky
I went to the farm show and tractor pull yesterday, and today was recovery/day off so I haven't had time to work on it. Maybe tomorrow.
idiotwithasaw
2:18 PM
Ky
I've had it apart a couple times. It's on right for sure. Im sure it was the fuel line, I tried to blow through it the way it was and was unable to blow through it easily. I need a new grommet but I'm going to use a smaller fuel line than the dealer used. Which I suspect was larger than necessary to begin with.
idiotwithasaw
2:18 PM
Ky
It's not that it was old. He just used the wrong one, it was pinched where it went in the tank.
Normzilla
12:18 PM
Cazadero CA
It will start and fire right back up. No opening the tank or anything. Just dies. I may fiddle with the carb. The gasket deal throws me throughva loop. At least they told me about it.
I would go back to the dealer. I'm with above 2 gaskets no thanks.
