Husqvarna 2100 thread
Normzilla
10:22 AM
Cazadero CA
Last I checked a Oregon 2100 clutch was still available. I bought mine, didn't run the spur sprocket
srcarr52
1:22 PM
Iowa City
288/394/395 clutch is a better design than the original 2100 clutch and goes on with no modifications. The clutch drum is the same for all of them.
Normzilla
10:22 AM
Cazadero CA
Nice must be what I have on mine then.
jb-chainsaws
5:22 PM
UK
Okay sorry guys but I've just got to post these pictures of the most travelled husqvarna in existence. Oh and did I mention beautiful too?
Also my first MMWS saw, cant wait to get it across the pond! image.jpegimage.jpeg
Brewz
4:22 AM
Hunter Valley - Australia
I was messing about with my 2100 tonight and noticed the the inside bottom tip of the chain that rides in the bar groove was oddly worn on one side.
I found that the 394/395 clutch and rim sprocket drum I have fitted doesn't quite let the chain align with the bar groove properly.
I will have to work out this alignment issue before I can use it for milling.
This would also be sapping power and would explain the performance not impressing me as much as expected.
Brewz
4:22 AM
Yep, found a 2mm dependency between an OEM clutch drum and the one I have.
Its an old GB one that their site no longer lists.
I think it will go in the bin and I will chase a different one
flying pig
11:22 AM
Grande Prairie, Alberta
My 44 was the same here last week. I found that fitting a spike like a bar plate gave proper alignment on that saw. Works good so I'm running it.
1:22 PM
As far as drives,mine has an 8 tooth rim and a 32" .It certainly doesn't have a problem pulling full comp,buried .In case nobody mentioned it those saws have some ballz even in stock form.
1:22 PM
After thought while it's on my mind.That rotten fuel line.
Clean that tank,pressure wash it or whatever you need to do,then do it again . If you don't I can assure you you will get very familiar with your carb because it will suck right passed the line filter and plug the carb screen < voice of experience here . I must have had mine apart half a dozen times .
Brewz
4:22 AM
Good advice, thanks mate.
Well do a triple clean on it.
Brewz
4:22 AM
It turns out that my 2100 running a rim sprocket clutch drum will only center the chain with the bar if I run it with no bar plate fitted.
I have tried it with the original clutch and other brand rim sprocket clutch drum and I get the same.
It had no bar plates when I got it, and was also running a spur sprocket.
I was thinking about taking some material off one side of the rim to allow it to center the chain with the bar slot?
Thoughts?
flying pig
11:22 AM
Why not just run it without bar plates? Mine has none either.
One of you guys had better buy that thing. My wife will rip me apart if I buy another 2100, especially one that wouldn't get run!
