Husqvarna 2100 thread
nv656
4:20 AM
Nevada
Fun fact, I purchased a non chain brake nos cover a while back that had the same casting numbers as the chain brake cover 2101. Leading me to believe that they were still making non chain brake covers well into the 2101 saws and just modifying the covers
Here’s a picture of all 3
Sloughfoot
4:20 AM
Norcal
It may be dumb, but just think how many 2100/2101s have been resurrected from problem piles just in this thread alone!
Mine's got a part on it from every problem pile ever. Learned a lot doing it that way and it only cost maybe triple what starting with a parts/repair saw would have.
hacskaroly
2100 Fanclub Member
4:20 AM
Northern Idaho, Ehh
NOW you tell me...
I agree...I could have bought a project 2100 that might not have needed a lot to get going, but I think going this route helped me develop a lot of confidence to get really deep into the saw and build it back out. I found that changing bearings is not as bad as I thought even without the correct tools. I used two boards, cargo straps and a rubber mallet to get the case halves back together, it was a hokey setup, but I did it (I have the correct case splitting and setting tools now!).
Through this project I learned a lot about chainsaws, it was a lot of work for me and helps me have a better idea/appreciation for future project saws! So I ultimately look at it, I didn't just pay for expensive used parts, I paid for experience that I have used on saws I have worked on since!
Sloughfoot
4:20 AM
Norcal
That's exactly why I went ground up with a 2100. Only thing I can give undivided attention to is what my hands are doing.
I highly recommend others do the same (with some other saw). There are several saws that are yesterday's tech, but not day before yesterday's tech that would be much better choices. Affordability and availability of NOS, used and aftermarket parts is key.
hacskaroly
2100 Fanclub Member
4:20 AM
Northern Idaho, Ehh
Yeah, I have a few 50's-60s' McCulloch saws that I am redoing from the ground up. They are not necessary the most desirable or have the greatest stock of aftermarket parts, but they will give me a great opportunity to learn metal repair and painting, if I screw up, no big loss. If it works out then I will have learned something and have a nice looking/running saw afterwards!
