MERR6267
- 1:04 AM
- Jan 19, 2016
- Ravenna, MI
The oil is delivered through plastic (rubber) lines behind from the tank/handle assembly and the crankcase. You might want to check those, as the oil will leak around the area. The pump arrangement is such that there are 2 lines from the tank, one that pushes oil from the thumb oiler and the other that the crank driven pump pulls from the tank. A little air leak in on hose or barb will be like drinking through a straw with a crack in it. Also check the small oring that seals the oil pump to the draw tube as it can suck air there too.
At this point I can't remember if you've had this unit apart this far, so forgive me if you've already been down that road.
Take care,
Phill
Take care,
Phill
