Catbuster
Roadbuilder Extraordinaire
- 3:13 PM
- Dec 28, 2020
- Lou, KY
So if you block that hole off they will rev higher . Would that be bad for them or will they handle it
I wasn’t there firsthand-worked left coast off & on ‘04-‘18-but apparently it was real common thing in the day, so to speak. The ones I’ve ran with them disabled have had them disabled since the 1980s and they’re still running. A 2100 will still lug down to 9000 in wood, it just helps limbing/other quick twitch stuff where you need to keep chain speed up. That said, it takes a strong man to limb with a 2100. I’d take every bit of help I could get.
Edit to potentially save the chainsaw: None of that means it’s smart to wind that saw up 10 13,000 RPM or so. That governor is supposedly set at 10,500 and there’s no real need to go a lot higher than that.
