Huskyboy meets 500i
Woodslasher
Teh debil
9:36 AM
Commiefornia
i can hardly even be considered a hack, but i think just about any modern 5 cube is gonna be floppy with 32” bar. 281/288 with stiff rubbers, not so much. thats the cost of spring smoothness i think
My 372 W with the stiffer tanks springs seems to handle a 32 pretty well, on the bench it doesn't feel floppy but I still need to field test it. Maybe someone needs to make one of those dog mounted spring setups a la 281/2100 for the 3 series Huskies. As for Stihls, this 461 a FS faller I know on another forum uses seems to handle a 36 just fine so it must just be the really modern Stihls that're floppy.
20210420_162920-jpg.1220022
dustinwilt68
Wilt Built Work Saws
12:36 PM
Southwest PA
It's the same basic av compound setup they use on there 60cc saws, not a fan, but they do pull well, thirsty for sure, and the filter is well, less then adequate to most, but they sell like hot cakes, most loggers in my area seem to like them, but like Mason they usually run a 20-24" on them, so the av isn't really an issue to them, fuel and filter and price are what I hear complaints about the most.
12:36 PM
So no more tank guard to protect from thrown chains on the 500i I noticed. The 462 has one... as did the 461, 460 and 440. Even the 572 has one, I liked that since the 372 did not have one. They must’ve done away with it on the 500i to save weight? It’s not a big deal, just something I wanted to point out. DC218932-5F92-4BF5-9DA0-D22E103D1E87.jpeg
12:36 PM
So no more tank guard to protect from thrown chains on the 500i I noticed. The 462 has one... as did the 461, 460 and 440. Even the 572 has one, I liked that since the 372 did not have one. They must’ve done away with it on the 500i to save weight? It’s not a big deal, just something I wanted to point out. View attachment 298158
I bet that’s a solid area with no fuel in it. There are a couple holes and a screw right behind there
Infinitejest
10:36 AM
Montana
That's where the control module doohickey lives. The 500 I just retired doesn't have a mark in that area, and it saw plenty of kicked chains playing in cedar. I do have the full wrap roller chain catcher, which probably helps negate violent chain throw.
FYI, the chip deflector is super thin on these saws, even with the full wrap clutch cover. Doesn't take many chain throws till you're chewing into the posts that hold the flap in place. I bought a few flaps and just fill the gouges in with Shoe-Goo as necessary.
12:36 PM
That’s some good points there, I bet the roller catcher makes a difference. I’m surprised the east coast version of this saw gets a metal chain catcher.
Doesn’t the control module live there? I imagine it’s not a cheap part.
12:36 PM
I’m wondering now if the fuel usage is exaggerated by the rather small tank capacity? That control/ignition module does take up a lot of space that would be normally used for fuel...
Sagebrush33
12:36 PM
Upstater
Stihl's specs show the 500 holding a bit more fuel. I believe the rumors to be true. The 500i is indeed a pig.
Infinitejest
10:36 AM
Montana
That's what I figure. Takes up a pretty good chunk of what would normally hold gas. They do improve a few minutes with break in. Which does take a while.
