I suggest Floppy, or Sir Pullsalot/primesalot
You get the idea I don't like them.
I get the idea you base your opinion off the internet and not from using one to feed your family..
It will do just fine for mason, hardwood cutting with a 24" and not floppy at all. Primer may as well not even be there because I never have to use it. Tad hard on fuel will be his complaint.. But the power and weight is where its at
I'm not sure where you got that idea, but I speak from personal experience. I just have bad luck with the 500i. I tried starting one at a GTG and had to prime it several times before it would finally start. It had not been more than 2-3min since it ran.I get the idea you base your opinion off the internet and not from using one to feed your family..
Oiler pin punched in... View attachment 297894A muffler mod... View attachment 297896View attachment 297895
It is a good looking saw. I mean for a Stihl, you know.View attachment 297886 Bout time....
Mebbe get the stiffer vibe kit from WCS?I'm not sure where you got that idea, but I speak from personal experience. I just have bad luck with the 500i. I tried starting one at a GTG and had to prime it several times before it would finally start. It had not been more than 2-3min since it ran.
I also use one at the place I work, and more often than not it is a huge pain to start cold or hot. Maybe I just haven't figured out the ideal starting procedure for it, but it shouldn't be any harder to figure out than any other saw. It should be simpler by design right? I try the recommended 8 pushes of the primer for hot starting, and we still trade it around until someone gets it going.
I have experienced first hand the squishyness of the AV springs and how it is floppy with a 36" bar.
I will say that the weight of it is not something memorable, which is a good thing.
This is how much fuel the saw consumed in 6 cuts in roughly 22” red oak. Definitely not a fuel miser. LolThats my only nitpick so far about this saw in my limited experience so far. It seems to make up for that in other areas. It’s one of the torquiest stock saws I’ve run in it’s size class. Thinking the fuel injection has something to do with this. I didn’t notice the saw being floppy with a 24” bar, I’ll try a 28” on it next. Maybe with a 32” it gets floppy?
Try pulling it fasterI'm not sure where you got that idea, but I speak from personal experience. I just have bad luck with the 500i. I tried starting one at a GTG and had to prime it several times before it would finally start. It had not been more than 2-3min since it ran.
Hey Duane, how big were the bars on those 500I's at your place?When saws miss behave, they get the piss flogged out of them. If they’re smart, they shape up...
