- 2:26 AM
- Jan 8, 2016
- Farmington, CT
heat or not, putting lateral force on a bearing is not good.... that tool he uses grabs from the outside of the case and draws the crank through the inner race of the bearing, possibly putting a flat on the bearings themselves. i see more danger in that than I do stripping bolts out of the case. you'll know if you strip a bolt, you won't find out till later if you flat a bearing.
also, I find it difficult to heat bearings properly, so i'll work on a tool
