Husky 266 Slofo-ized
ZukiRyder400
Breaker of recoils
8:27 PM
NY
This is my plan as of right now
  • Cut .035 out of the band, gonna be running a gasket but I forgot what thickness gasket my pa uses. Ill double check tomorrow. Squish is gonna be .020”
  • Timing for start: EX:102 TR: 121.5 IN: 78.5*
  • Pretty extensive transfer work, lowers and uppers.
ZukiRyder400
Breaker of recoils
8:27 PM
NY
I mean hey the Hooskies are the ones makin all the money at my house. Them darned creamsicles always seem to keep breaking on me:D:D. LOL just kidding. I gots to do up an 044 046 hybrid soon. Running Dans CFB made me want one pretty bad
Ronie
8:27 PM
NC
I did one with the same numbers as your going to use a couple of years ago and it wasn't high reeving, but had real good torque.
ZukiRyder400
Breaker of recoils
8:27 PM
NY
Lowers roughed in. When I go in to do the uppers, I need to go into the back wall and angle them towards the intake more because they are semi flat. 4B999F2F-9092-454E-B598-39FA20D8DE99.jpeg34A88AAC-AB6E-4A6F-81D8-E35563C3047D.jpeg
ZukiRyder400
Breaker of recoils
8:27 PM
NY
I MIGHT try out a 281/288 Tillotson carb once its all said and done. They have the same exact sized venturi, same body, heck even the same choke and throttle throats are the same size! Same bolt pattern (Walbro RWJ-4 style) too. Thoughts?
ZukiRyder400
Breaker of recoils
8:27 PM
NY
Have you even run the other one you built?
Yeah I have. The first one I did turned out to be pretty solid. It gained a good amount from just doing that lower transfer work and gained even more when I dropped the intake a little bit (76 degrees before, 78 degrees after). Im not just hogging things out either, even though it seems like it.
PA Dan
8:27 PM
White Oak PA
You mean the one you broke...?
ZukiRyder400
Breaker of recoils
8:27 PM
NY
Baseline cuts, All I did was drop the gasket, bring the ex back to stock height (105*), and readjust the uppers. More to come:)
